Here's my quick, easy & economical alternative.
This is my first instructable - so please bear with!
PLEASE NOTE: SOME OF THE STEPS INVOLVED CAN BE DANGEROUS!!!
READ THROUGH ENTIRE PROCESS FIRST AND FOLLOW DIRECTIONS CAREFULLY!
POTENTIAL ELECTROCUTION HAZARD!
PLEASE BE SAFE, VENTILATE WELL, POTENTIAL FOR HAZARDOUS FUMES!
POTENTIAL FIRE HAZARD - KEEP A FIRE EXTINGUISHER RATED
FOR ELECTRIC FIRES HANDY!
YOU'LL NEED:
-An older style steel electric waffle maker with removeable waffle plates.
Pretty doesn't matter, functionality does - see image.
I see them for sale regularly at yard sales & 2nd hand shops for a couple of bucks.
(I've seen newer styles that seem to be a light aluminum, no experience with these)
-Probe thermometer.
(Our particular thermometer is a 'flue' thermometer, meant for use inside
a chimney. They're available in a range of temperatures - for our use, we need one that
can read up to 1500F. Available at wood stove resellers, or possibly ordered from an appliance supplier - Cost? Approx: $30.00)
-Insulated container of some sort to house the waffle iron.
(old metal refridgerator drawer, small propane barbeques, less the inner parts,
work great too.)
-Agregate, or other insulating material.
-Insulated/Fireproof fibre matting.
(may be purchased at some welding shops & most hot glass facilities/shops)
Optional/fire brick - kiln liner brick.
(Kiln liner brick is exactly the same as stove liner brick, however, stove brick is
a fraction of the cost and can be easily purchased anywhere wood stoves & said
accessories are sold)
Tin foil. The heavier guage, the better.
Can of spray brake cleaner.
Remove these ads by
Signing UpStep 1Cleaning & Prepping the Waffle Kiln
(keep in mind, my mini kiln has successfully ramped up to 2000F - these handy
plastic handles & feet will melt like candy if not removed - I'm pretty sure they'll smell bad too!)
Remove waffle plates.
You are now faced with an shell of a waffle iron, complete with elements, wiring,
ceramic posts that hold the elements, and some whatnot gagetry.
It's probably really greasy & dirty in there - any grease or carbon fumes/smoke emitted
during your anneal process could leave smudges & imprints on your glass projects.
(not to mention a heck of a smell, probably...I'm not big into nasty smells...)
Take the iron outside & shake any loose gunk out.
Wipe any excess you can reach with paper towels.
Key words here...SAFETY & VENTILATION!!!
Take the iron outdoors & place it on the ground or on some other heat proof surface.
Place it somewhere away from highly flammable objects.
Spray the insides liberally with brake cleaner. (don't inhale the fumes - brake cleaner is nasty!)
Spray the inner wiring & coils, anywhere grease may have collected.
Try to avoid letting the brake cleaner run out onto any outer wiring - if so, wipe it off.
Let it sit for five minutes & then plug it in & fire it up.
Be ready...this will be messy, smoky & potentially scary!
FIRE HAZARD!!!
Keep your fire extinguisher handy, just in case.
(be aware of local fire bylaws, perhaps your neighbours don't have THAT great a sense of humor...)
As the iron heats up, it will begin to smoke. Alot. Even more. Still more!
It may even catch fire - although this should last only a minute or two at most.
(here's where the fire extinguisher comes in handy, just in case...)
Keep an eye on the outer case of the iron - it probably won't get too hot, but you'll need to
I didn't find it was necessary - but can't hurt to think ahead!
I simply pulled the cord directly away from the iron before I plugged it in, so it wasn't
lying right next to it & covered it with the foil to sheild it from any direct flame.
Once the whole mess has stopped smoking, unplug it & let it cool down.
A power bar is handy for this step, as, if a problem occurs, the power bar
should cut power, or, you can quickly hit the switch before unplugging the power
bar & not have to worry about having to touch potentially hot electric cords...
There you go.
Do you think this method could be used to build a small Kiln for burning out wax in lost wax casting?
I'm thinking about gutting a used table top grill for the heating elements.
I don't see why not -If you can't find a suitable "waffle iron" there's no reason you couldn't build your own - a metal box - lid, insulate the inner with stove bricks, scavenge some elements, insulators & other necessities, and build to suit!
(it's one of those projects on my ever growing "todo" list - I'd be interested in how it goes for you if you do try... )
Good luck!
I live near a good will. I intend to simply pick up one of those George Foreman type grills, they normally have a dozen of them, and strip it. I need something that can fit a crucible though as I'll be using it for investment casting uses.
You also mention keeping a fire extinguisher handy - some are water based and should not be used on live wires!
Very cool, but way too risky for my blood!
(do you drive? Don't check the 'risk ratio' involved in auto accidents then...)
Yes, that would be something to check on...and I guess I should have mentioned that! (I've done alot of kiln building/repairing, and that's what's so awesome about Instructables, if you've forgotten or omitted something, there are always peeps out there willing to help!)
When in doubt, do check! (I did mention ventilation...and I've done uber amounts of research on this over the years, although, my research certainly isn't going to stop someone else's foolish behavior, as Patrick pointed out...LOL)
Investigation & research turns up alot of useful info on this sort of thing.
www.asbestos.net is a valuable resource.
The insulators are made of ceramic, very much the same as those used in a more modern kiln setup, if a different shape.
If the wire covers in any particular item are white, and unbound, it's very highly doubtful that they would, or could, be asbestos. Unbound asbestos wire cover becomes 'friable' (disintigrates) in a very short amount of time.
(for that matter, why anyone would use any electrical appliance that had frayed wire or insulation is beyond me...)
Keep in mind that asbestos is most hazardous when it's in a friable state, meaning the dust particles can become airborne.
(very much the same as fumes from glassblowing/lampworking & dust from bead release & kiln wash can be hazardous)
This is far more of a hazard in home and industrial applications, around furnaces, insulation, in walls, ceilings, floor tiles and roofing materials where it may fray or dust may become airborne during renovation or construction projects, and for those who frequently repair old appliances such as crock pots and popcorn makers.
(I worry more about whats in my old home...I happen to KNOW the old wiring was asbestos, and I'll tell you, that wasn't fun! Makes one wonder what else may be lurking in the walls)
Most often, this type of wiring is a sleeve made of fiberglass, safe unless it too becomes brittle and the particles may become airborne.
Of course, if one is uncertain, it's simple enough to replace those wires, after all, the iron is already half disassembled.
As for the electrocution hazard...I have two modern (circa 2000ish) "pro" glass kilns, and one very large (circa 1970) ceramic kiln. Their elements aren't covered either.
Vapors, yes, nasty, dangerous, but a risk easily taken care of with proper ventilation & masks. Been done for many years.
(If you're into lampworking, or anything involving fumes, (I'm guessing not, but you never know!) I have a mega huge list of safety resources & such that I've compiled over the years, if you want a copy, just let me know!)
Anyway, so, everyone...listen up!
NO ASBESTOS!!!
DON'T POKE ANY EXPOSED WIRES OR ELEMENTS!!!
WEAR A DAMN MASK & AN APRON!!! (rubber boots and a stick add to the costume immensely!)
STAY OUT OF VEHICLES!!! (just joking Tina!)
Still doesn't help with the original electrocution aspect, but I guess you could also always plug into a GFI. And wear a rubber suit, carry a rabbit's foot and a rosary . . .
This is a wonderful 'able. I've been fusing glass at 1500* in a small high fire kiln (overkill) and plan to experiment with the wedding present waffle iron c. 1977.
(I fell on a cut open large power cable when I was a kid & got a major electrocution - my sister used to say "that's what happened to her...)
So, the power strip was a necessity for me! :)
I'm sure I was a sight doing this too...
I wore my rubber boots, overalls & welding mask and carried a big stick!!!
(sounds like something out of a scary movie...)
Good luck, I've planned to do some fusing in this little guy using a small fire brick covered with kiln wash, yet I've never gotten around to it.
Do let me know how it goes, if you will.
(circa 1977 - in some ways, that saying "they don't make em like they used to" is most certainly true!)
1 suggestion: I don't know the temperatures that you use for enameling metals but I would suggest that if you want to add a window to a kiln use fused quartz glass instead of borosilicate (pyrex) glass. Quartz glass has a much higher melting point and is the standard for high temp viewing windows. Good luck.
Yep, we used to be able to get it, but I'm not certain anymore.
We heat with wood stoves, and the "Safetly Standards" stuff sure has changed over the last few years. I'm not sure you're even allowed to use Mica anymore, too bad too, we have a georgeous antique corner stove, and I'd like to have an insert put in it to make it airtight, but I believe I'd still have to remove the mica, I'll have to check for sure.
Thanks for bringing that up!
Pyrex might do, but you'd have to be sooo careful!
(and attentive too - something I'm so not good at!!!)
Pyrex - or Borosilicate - has a different COE, and melts at approx.
1570 F.
(old corningware makes some awesome bracelets!)
I've easily ramped this baby up to 2000 F.
I'd have been so dissapointed if I'd have melted it!
(I already have lots of melted 'experiments')
A great idea for a PMC kiln though I would think.
That is, only if one wished to observe what is going on inside.
If one opts for a high amp, multiple position switch, they still need something (some form of high temp probe) to detect and regulate temperature. Many high amperage devices are expensive new....but if one lives near an appliance reclamation place, one may be able to pick up something for very cheap. Or, as someone suggested, the used appliance shop.
I did once kinda get 'distracted' and by the time I realized it, the coupler read
2000! Once I peeled the melted glass off & fired it up again, it was fine.
(and when it's cold, you can tuck it under your arm & off you go)
Just keep the kiddies away - it does get really hot!
(might be able to roast a marshmallow or two if you're close enough!)
Good luck with the Scouts!
I hope that helps
Pat. Pending
