3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wah button
Wah button
Most people who own a Dunlop CryBaby Original wah would probably agree that all in its not only a great pedal for the money ($79) and that its a ton of fun to play around with. The only problem I have run into is that it requires a good amount of pressure to activate and deactivate something that proves difficult while doing fast switches during a song or while playing while seated.. Basically I figured an absolutely free way to fix this problem. This is my first instructable ever and I hope this helps you out!
Step 1Stuff you will need
Obviously a cry baby pedal
Glue or duct tape or poster adhesive
A flashlight
Scissors
and a guitar pick
22 comments
May 20, 2009. 2:08 AMbigredlevy says:
This is alright for a temporary fix, but the pedal can be easily modified.
I modified my VOX wah, which has a very similar enclosure, buy removing material from the rubber stoppers. this gives a bit more travel = a bit more wah to play with.
The metal DPDT switch has a nut on both sides of the enclosure, to allow for height adjustment.
personally, i like the switch set low. if it's too high you can easily bump it when your really jumping on the pedal in the middle of a riff.
Aug 18, 2011. 2:49 PMnascarbean_97 says:
I agree with these guys.
But I'd rather just stomp on my wah to turn it off and on than make it easy to accidentally do it.
Jul 15, 2011. 2:59 PMthestoopididiot says:
YOU COULDVE JUST TAKEN OFF THE RUBBER THINGS,EASIER SWITCHING AND WIDER SWEEPS.
May 2, 2010. 1:53 AMlullaby21 says:
You could have just screwed the switch up a little higher like everyone else and there would be no need of glueing around...
Apr 24, 2010. 9:50 AMjonnylove says:
 um... you know that the switch height is adjustable via a nut on the inside of the pedal.. its a simple adjustment that will fix your problem permanently
Apr 8, 2009. 4:14 PMlemonie says:
Do I understand that the pedal is either badly-designed or badly-constructed? Your simple shimming trick compensates for what the manufacturer should have done better? L
Apr 8, 2009. 11:49 PMlemonie says:
But it does work better with a modification. I suppose that I'd actually have to use it to appreciate it - thanks for the reply.
L
Apr 10, 2009. 3:49 PMIbanezfoo says:
Thats subjective. People with giant clodhopper feet would probably want their switch to be less easy to press. I myself prefer the foot-on-pedal type switching. Its all up to the user. The general unit is built like a tank and the circuit sounds good. No design flaws. You can change it to suit your needs by modding switches, changing inductors, moving the pot/linear gear link, etc...
Apr 10, 2009. 4:11 PMlemonie says:
Thanks for using the phrase "clodhopper", there was a comic years ago that had a strip called "Claude Hopper" - I had never expected to run across that again.
My original query was along the lines of "how does a bit of shimming make this significantly better?" But I think you have answered that.
L
Apr 9, 2009. 7:13 PMpsychodeathmonkey says:
Does anyone know if i could add a pot somwhere in my wah pedal to control the pitch of it? ive been kind of curious about it and really dont feel like shelling out 200 dollars for a whammy and 25 bucks for another power strip/supply. If anyone knows id appreciate it.
Apr 9, 2009. 10:49 PMMrCakes14 says:
Do you want to control the pitch or the frequency range?
Apr 10, 2009. 6:49 AMpsychodeathmonkey says:
The pitch, have a potentiometer that controls the pitch but also be able to take it down to normal pitch also maybe an on off switch on there too.
Apr 10, 2009. 8:49 AMMrCakes14 says:
Hmm...I may not be sure what you're asking, but as far as I figure: a) that's what the pot in the wah already does when you move the expression pedal -or- b) it can't be done...the best you can do is put in a rotary switch to change the value of the capacitor that controls the center frequency of the bandpass. (I hope that made sense). If you want an expression pedal to control pitch, go for a Whammy™, because you can't mod a wah to do that. -Cheers
Apr 8, 2009. 6:36 PMgmoon says:
Customizing a pedal is up to the individual--Hendrix used to remove one of the rubber feet on his wah, giving it just the right tilt (for him.) Raising the height of the bypass switch might make switching too sensitive for some (I assume it you didn't raise it so much that it reduces the wah range...) but if it works for you, cool.
Apr 10, 2009. 3:55 AMgmoon says:
Yes, but there's also a crew of volunteers that do stuff like featuring. Maybe they're the "Jr. Censorship Police", too.
Apr 9, 2009. 6:29 PMgmoon says:
Wow...that polite exchange we had has been "sanitized?" This community has really gone downhill...
Apr 9, 2009. 5:33 AMcrapflinger says:
you could actually remove the on/off switch (i guess it's the bypass?) from the contraption where it's currently located...and relocate it off the pedal....like to the side or something...then you can hit it with your foot then go right over to the pedal...though i assume that they put it where it is so that you don't have to do too many things to get it to work
Apr 8, 2009. 7:45 PMgmoon says:
Well...either it makes it easier (and more sensitive), or it doesn't... Like I said, if it works for you, cool. (There are projects here and and elsewhere that use momentary switches mounted on the treadle--remove your foot, and the effect cuts out. Replace your foot, and the effect is back. Some prefer this also because the effect can stop or start any where in the wah range, not just up at the treble end...)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mabu4237
I'm pretty prompt about responding to any questions and if anyone needs more details on a project feel free to message
