3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wake skate construction - Step two.
In step 1 I showed how to make a wake skate jig. You can see the process here:
http://www.instructables.com/id/Wake_skate_jig_Step_one_of_making_a_wake_skate/
In this instructible i will show how to make the wake skate.
I did some research on the web using the following sites:
http://www.wakeskating.com/forum/viewtopic.php?t=2317
http://waterdancing.blogspot.com/2007/07/build-wakeskate-from-scratch.html
http://www.ehow.com/how_2081891_build-wake-skate.html
http://forums.wakeoutlaws.com/t1015.html
http://forums.wakeboarder.com/viewtopic.php?p=98708&sid=2e09a927420901b231cabe8b291b01dc
And following some links on those sites.
I decided on what I believe to be a two stage rocker with dimensions of the board being 1000mm in length 375mm width and 174 tip and tail width with an approximate 50mm rocker. I took an image off the web to scale up and copy.
Step 1Cut plywood.
Cut plywood.
Cut your plywood into 400mm x 1100mm you will need between 3 and 5 of these sheets. It depends on the quality of the ply and how strong/light you want the final product.
7 comments
Jan 9, 2012. 12:41 AMbblan17 says:
i'm thinking of making one which type of ply did you use
Oct 9, 2010. 11:33 AMadam23 says:
my son is thinking about making a wakeskate as a 8th grade shop project. do you think this is too hard for a shop project?
Nov 2, 2008. 3:10 PMb-train says:
how did it go? did u give it a run on sunday? im building my jog atm cept i thought i wld savesum money and use hardwood that we have, cept i forgot i dont have a bandsaw n cutting it out is taking forever, haha hope ur board worked well :D
Oct 28, 2008. 3:12 AMb-train says:
Suhweeeeet!!! the 2 part rocker looks really cool, when u said u fibreglassed it u mean u only used the resin right? Looks really good, i cant wait till i finish the HSC and have sum spare time. Or at least spare time that wont make me feel guilty for not studying hehe. 5+
Oct 29, 2008. 4:42 AMb-train says:
haha sounds like my projects, i see, all there is in mudgee atm is 1/8th plywood for 30bucks a sheet, n it pretty crappy, im hoping i can get sum junk thats already half warped, hahah thanx only fisics, chem and engineering to go,
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:njacksx
