Step 6: Tongue damage
As well as damage to the inside there was also external damage to the bindings. You fix these worn areas in much the same way as the internal damage.
Working with small pieces of sugru at a time, press it into the surface of the boot.
Rub the sugru into and around the damaged areas, forming a thin layer.
It was slightly less simple to apply the sugru to the outer material. If the sugru becomes sticky, again make sure that your fingers are cleaned. Use dry tissue paper for this.
TOP TIP: If the applying of sugru to a fabric becomes a bit more difficult like in this instance, use your fingernail to rub the sugru into place. Sugru sticks less to your fingernail, giving you greater control of the hack.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
