3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Walking Papercraft Mech Warrior
Step 11Glue page 3
Glue page 3
  • last photo ←
Start by taking part 9, applying glue on one half of the one white side and placing it on the underside of the base. This part helps reinforce the base, preventing it from flexing, which can cause it to break. If you are using a heavier weight of paper (about 40 lb and up) you may not need to use this part.
Now glue parts 12-19 into a square shape, refer to the pictures to ensure you are doing it correctly.
For parts 14, 15, 18 and 19 there is a flap on the end that also needs to be glued down. To do this apply a small bit of glue to the opposite side of the square (where there is a slight whiteout in the colour) and press in place. For parts 13 and 17 glue the end flap closed.
To create the cam follower assembly, start with part 12. Take part 13, apply glue to the triangular flaps and position them over part 2 as seen in the picture below.
Next apply glue to the inside of the flaps of part 14 and place it on the labeled portion of part 12 and make sure the seam on the end is facing away from the direction the upper portion of part 12 bends. Do the same with part 15, making sure the seam is facing outward.
Next take parts 16-19 and repeat the above steps, just mirror the side that parts 18 and 19 are glued on. Refer to the pictures because it is important to do this correctly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
98
Author:J_Hodgie
Currently doing masters in Mechatronics Engineering, but still create in my spare time
