3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Walking Papercraft Mech Warrior
Step 9Mount The Cam Assembly
Insert the cam assembly into the base shell. Start by putting the longer side of the axle through the hole in the side the top portion is attached to. Push it until the shorter side can fit inside the shell then push the cam assembly back through the hole in the other side.
Take you time with this step, if you rush it you are very likely to tear the paper.
Apply glue on the closed end of the main axle and press part 23 in place on it. You will want to make sure the corners of the axle are flush with part 23, otherwise the paper could get caught and bind the mechanism.
Slide part 24 over the open end of the axle, line it up with the guide line and glue it in place the same way you did for part 21 and 22.
Glue the remaining end of the axle closed.
Glue parts 25 and 26 into a square. Apply glue on the inside of part 25 in the end missing a section and attach it to the axle at a 90 degree angle. Attach part 26 in the same manner to the end of part 25, facing the same direction as the axle (See the last picture).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
98
Author:J_Hodgie
Currently doing masters in Mechatronics Engineering, but still create in my spare time
