CMU's robots are called STRIDE, for Surface Tension based Robotic Insect Dynamic Explorer. They mimic the way water strider insects "walk" on water.
I wanted to see how difficult it is to make a "robot" that moves on top of the water surface, purely based on surface tension. I found out that recreating the principle is not hard at all.
When carefully putting the construction on the water, the surface tension keeps it on top. When disturbed, the construction sinks, proving it is really the surface tension that does the trick.
The vibration of pager motor gives it some rudimentary propulsion (both on land and on water actually).
I hope this experiment inspires you and I look forward to hear what you can do with it. And of course, your vote is welcome.
Remove these ads by
Signing UpStep 1Materials
A test showed that the small diameter carbon fiber reinforced rods work fine. You can find these "carbon" rods at modeling shops stocking indoor flying materials. I used two 0.8mm diameter rods, about 1 m in length. The more commonly available 1 mm diameter rods are probably also worth a try.
The other materials used are:
A small a pager motor
A small 1.5V button cell battery
Some scotch tape
A tiny piece of double sided tape
As for metal rods, these will be rather heavy, and solder will be heavier than tape. You can try, but I really recommend carbon rods of maximum 1mm diameter, available at hobby shops selling RC airplane kits and probably at kite shops to. if you can get 0.8 or 0.6 mm, this will be even better.
for mor info on low voltage motors and water, see: http://www.instructables.com/id/Simple-solar-powered-pocket-submarine-with-depth-c/
The motor would need to be mounted on some pillar and a problem might be the pillar acting as a lever and the propulsion force pushing the front of the construction down.
According to this website, it translates as νταση, υπερνταση (I have no idea if that is correct!).
