Walkman Ipod Case - DIY
 by handsomemanny
Step 2: Putting it all together
Step 2.
 - Gut the Sony Walkman, leaving the headset jack and electronic board in tack.
 - Cut foam to fit snuggly into the bottom of the Walkman (use layers of foam if you can, makes it easier to cut the next step)
 - Trace the iPod onto the foam (should be similar thickness to iPod), Cut it out with a pair of scissors. this will keep the iPod from moving around. Glue this piece onto the bottom piece.
 - Solder the headset wires to the headset jack board. L on Left, R on right and G on the Ground (white wire). To be sure it was working, i had my head set plugged in the Walkman and the cut off piece plugged into the iPod...this allowed me to hear when i made the right connections.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
