Wall-E Robot
Wall-E Robot
  • last photo ←
This is my Wall-E project that I am currently working on it is 150mm x 150mm x 160 high, it uses a pair of Mattracks http://www.litefootatv.com/html/litefoot_in_the_news.htm for motive power and two robosapienV2 hip motors. It will be controlled by a BS2P40 stamp CPU and will have the following functions described below.
I build robots quite prolific but my let down is programing "hopeless but learning" I have a friend at http://www.robocommunity.com who is programing it for me, From this I hope to learn how this program is put together and eventually program myself. We are in the progress of designing the H-bridge for the motors using the L298 chip, The head is finished apart from his adorable eyebrows which http://www.musclewires.com/shapememoryalloys.shtml wire or Muscle flex and pan/tilt has been run.
The main reason for building this project was to see if I could use parts from my stock of components that I have lying around my basement and electronics room, The only thing so far that I have had to buy is the Mattracks , uOLED screen and L298 H-bridge ic. Which GWJax is sending me. I was inspired to build this project after seeing a Pixar demo video and thought WOW what a neat bot to build.
I have been in R/C scale and other unorthodox aircraft for over 30yrs and modeling is my passion, so this comes in handy when creating something like Wall-E. I hope you like how it is coming along. I would also like to add that GWJax has been an inspiration to me on the programming side.The main construction of Wall-E is 5mm lite ply, sides,front,back and top, with 2mm balsa cladding on the sides with some 1.5mm ply to form the raised panels. Rivets were made using PVA glue watered down 40% and applied to the required area's with a sharp pointed rod, One dip will give you 3 rivets. The arms were constructed out of 1.5mm ply and balsa, and uses 4 of my Technics air rams back to back, The fingers were modded Technics angle beams covered in 1mm ply for the sides and balsa top and bottom.
The base is constructed out of 5mm Acrylic sheet as this is good for boring holes to mount your fittings. the head H'mmm a real challenge here, I had to draw it out first to get the pear shaped eye right then work from there. The main eye tube was a pair of alloy pill containers which worked out to be the right size for the head. The Blue LEDs x 6, 3 in each eye are mounted on a 5mm acrylic disc and inserted in the tube about 2/3rds down, then another Acrylic disc in front with the ping sonar in each eye.The ping sonar is from TX and RX had to be removed from the board [tricky and an extension lead [screened] run from the board to the Tx and RX in each eye. I was not sure at the time if this would alter the characteristics of the range, but after testing this was unfounded.
The eyes light up at present using a circuit which has a CDS cell and when you switch the lights of the eyes come on, GWJax may code this to work also with some other functions on Wall-E.Wall-E was finished with off the shelf spraykote enamel cans, grey primer, followed by antirust primer, then layered with yellow, rivets applied, then sliver over the rivet area, followed by an airbrushed rust over the rivets. The whole body was then rubbed with scotchbrite pads until the rust and some silver was showing through, then airbrushed with a mix of satin varnish and grey primer to give Wall-E that weathered effect.The head was done in a similar way but with different colors. Phew, I think that's it guys. Check out my web site.
http://robosapienv2-4mem8.page.tl/ Robotic Madness
1. Use my Mattracks as the main drive unit
2. Motor drive gear motors using H bridge controllers
3. Pan/tilt head using Parallax ultra sonic ping
4. 3 GP2D12 IR edge detectors or similar detectors
5. raise and lower the arms as a pair [up and down only]
6. raise and lower the front door
7. [Maybe not sure yet] raise and lower the head
8.Use Parallax ping in both eyes
9. airbrush Wall-E to look authentic as possible.
10. Fit a uOLED in the front panel
11. Use a Parallax emic text to speech chip for wall-e's voice
12. Fit Ultra bright blue LEDs in Wall-E's eyes
13. Make a pair of H bridges for the drive motors
14. solar cell to charge batteries
15. voice changer circuit for Emic text to speech
16. Speaker
Step 1Gear motors
Gear motors
RobosapienV2 Hip motors with bevel hex gear.
367 comments
1-40 of 367next »
Oct 27, 2011. 11:22 PMdfelisilda says:
love it <3....
Jul 28, 2008. 7:39 PMjirus95 says:
just saw it I loved it!!!
Aug 27, 2011. 9:48 PMganeshsanjeewa says:
Nise work Dud!
Maxxa robot aha!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Aug 1, 2008. 8:39 AMLtcheesecracker says:
u forgot the WALL-E logo on his chest!
Feb 4, 2011. 9:52 AMGeneral FOL says:
Hi, how is this project going?
Oct 6, 2009. 6:34 PMbears0 says:
cool put a vid on it
Jul 10, 2008. 7:19 PMAnthony312 says:
what you could do is place some cameras in the eyes so u can see what wall-e sees.
Jun 24, 2009. 9:01 PMSnuffyDaPenguin says:
Not sure if you're still working on this project, but I suggest mounting a camera just between and below his eyes, between the two sockets. Then he can have collision avoidance and could be followed/watched from a computer anywhere you wished.
Jan 28, 2009. 4:39 PMDELETED_DELETED_DarthVader says:
(removed by author or community request)
May 27, 2009. 10:09 AMDivideByZero says:
DarthVader: That can be classed as spamming, I think.
May 27, 2009. 10:10 AMDivideByZero says:
And no, I don't normally do that, I just felt the situation was appropriate for it :P
May 27, 2009. 10:13 AMDivideByZero says:
Or should it be "DivideByZero: And no, I don't normally do that, I just felt the situation was appropriate for it :P" ??
Mar 23, 2009. 12:36 PMrorpen says:
Stop doing that!! Are you copying and pasting?
Jul 15, 2008. 10:06 AMAnthony312 says:
ok i can understand that. But i saw these cool cameras that would fit in wall-e's eyes and still leave room for motors and wires and stuff. they're only 0.3 in. by 0.3 in. by 0.4 in. And when i watched some wall-e videos closely, i found out that the lense part of wall-e is hollow, which means it can be use for zoom and focus. this also helps when wall-e has to turn into a cube.
Jul 15, 2008. 11:13 PMAnthony312 says:
oh...ok then. but im going to build my own wall-e robot, and im going to use cameras (and if there's room ill even do that LED and sensor thing like you did) and it will have one special feature that no other wall-e robot (that ive seen so far) has ... it can turn into a cube!
Jul 15, 2008. 11:15 PMAnthony312 says:
though im working on how he would be able to compact trash (thats for later).
Jul 18, 2008. 7:05 AMCapnTac says:
I hope you put up an instructable for it! Good luck making him roll up into a cube, that seems really hard. For the trash compacter thing, simply put metal squares on pistons inside of him, then when you put the trash inside of him, you could activate the pistons, and he would compact the garbage. Just a brainstorm.
Jul 21, 2008. 7:16 PMAnthony312 says:
But the Metal squares will crash into each other, and plus they will leave no room for the rods that will bring wall-e's tracks up when he has to turn into a cube. plus the metal squares wont leave room for the tracks themselves. Anyway it doesn't matter, i dont care about the trash compacter as much as i want wall-e to go into cube form. Thats what i want most.
Jul 24, 2008. 3:36 AMAnthony312 says:
I have never had the time or the money to completely finish a robot, but I have made many electrical circuits and contraptions with the parts I have laying around on my desk. I don't have enough money (or time) to buy all the parts I've needed to complete a robot, and I already have plans with what to do with the cluttered junk on my desk (I'm going to combine it all into one electrical contraption) so I'm out of parts basically. I also don't have the time to finish a robot because I'm very busy with school and homework and reading books and watching TV and playing on the computer (like I'm doing right now). So right now I'm just researching and making plans for all the robots I will be building in the future (which of coarse includes wall-e) and making sure they're all foolproof. I've lost count with all the plans for the robots I'm going to build. So I'm waiting until I have the time and the parts to finish a robot.
Jul 26, 2008. 10:08 AMAnthony312 says:
Thanks. Now what were you going to say earlier?
Jul 27, 2008. 10:57 AMAnthony312 says:
I know how hard its going to be to build. But don't worry, i've got a whole lifetime to build it. It will be finished sooner or later...and thats a promise!
Jul 27, 2008. 11:03 AMAnthony312 says:
But lets get back to what i was saying earlier. do u have anything to say about the comment i stated after yours to CapnTac (its the comment at the bottom of this conversation) and if you do, please reply on that one, this one is getting cramped.
Aug 4, 2008. 11:59 PMAnthony312 says:
hello!?!?!?! Anyone there! 4mem8 why haven't you answered yet?!?!
Aug 14, 2008. 10:31 AMAnthony312 says:
Still no reply...are you ignoring me or something?
Jul 21, 2008. 7:39 PMAnthony312 says:
I know exactly how hard this build is going to be. I am well aware of the space effiency of wall-e too. The reason you have no room is the size of your motors and servos and maybe even the electronics. They make smaller motors you know. and why do u need that huge gearbox attached to your motors when you can just connect the motor directly to the mattracks without the gears. and you can use a smaller recorder for wall-e's speach. When i examined wall-e the eyes only take about as much room as the bottom of the solar charge level screen up, and the tracks take as much room as the hollow trash compactor inside wall-e, which happens to start from the bottom of the solar charge level screen down. And his eyes are not as wide as the entire of wall-e itself, as a matter of fact it is 2 wall-e arm widths smaller. so as far as i can tell, wall-e turning in and out of a cube is plausable. There is even room for the solar pannels (they can replace the battery if you charge up long enough) and one or two small microchips fit (you can use 1 for speech and 1 for charge-up panal).
Aug 19, 2008. 4:25 PMGWJax says:
WoW I just read all your comments, I am working side buy side with 4mem8 on this project as he has built him and I'm doing the programming for it. Just a little FYI for you, there is alot more to this than just adding a few micro chips. plus 4mem8 had used those gearbox motors for torque issues being that the Wall-E is not that light. Even if we use SMD's to make all our boards there still will not be enough room to box him up. CGA is a great thing to play with but in real life the physic just arn't there for that to happen. But I hope you do find a way to make it as I will be looking out for a wall-e that can move around it surondings and then box its self up. Good Luck Jax
Aug 21, 2008. 11:33 PMAnthony312 says:
I've read your comments too, I know that your helping 4mem8 program his wall-e. anyway about the torque, I'm planing to make a much smaller wall-e than 4mem8 and thus am going to use a smaller motor and less power and torque, so a HUGE gearbox isn't neccesary. I'm planing on first making a small toy-sized prototype wall-e (to see if he can go into cube form, which I know he will), then later, if I have a lot more money and parts, will make a full-size wall-e (by full size I mean about the same size as 4mem8's wall-e). The prototype wall-e is the one I'm making plans on right now.
Aug 19, 2008. 11:33 PMGWJax says:
no problem 4mem8 I hope he does make one that will box up, I guess if you enlarge it enough you might beable to do this but the tracks must also reform them selfs. A very hard project even for the best. Jax
Aug 21, 2008. 11:37 PMAnthony312 says:
I know about the reforming tracks problem too. My prototype wall-e that I'm working on right now is too small to reform its tracks so they're going to be cubed in the way they are instead of changing its shape. on the larger wall-e I hope to make the tracks able to reform when going into cube form.
Aug 22, 2008. 7:17 AMGWJax says:
Anthony312 Keep us up to date with your progress, I know your protype will probly not have any electronics on it which is fine, But at least you can see that retraction of the tracks are needed and if you keep your wall-e light enough you may not need the gearbox motor, I would use a standard servo for the drive system in this case. Just remember to keep it as light as possable. When you get it right you'll have to enlarge the Wall-E 2 to 3 time the size of 4mem8's wall-e just to get everything inside. Good luck and I hope to see you get it done. Jax
1-40 of 367next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:4mem8(clw woodcraft)
a busy busy man with his hobbies lol.
