Wall Led Lamp
1,634
47
4
Published
Introduction: Wall Led Lamp
This lamp is constitued by two aluminium C shaped channels with a led strip lamp inside.
I hanged it on the wall, using two hooks that were fixed by former inhabitants.
Step 1: Piercing the Aluminium Channel
I drilled two holes to hang the lamp on the hooks.
Step 2: Cutting C Shaped Spacers
I was planning to glue the two channels back to back but my led strip wasn't flexible enough.
I decided to cut some pieces of the channels as spacers. Their length is equal to the width of the channel (more or less, I'm not very precise with a saw).
Step 3: Glueing the Channels
I used epoxi glue to fix the parts together. It was my first test of this kind of glue and I wouldn't choose that option again. It's not as strong I believed. Small screw and nuts Would be better I guess.
Step 4: Glueing (or Not) the Led Strip
Same disapointment with the glue and the led strip. It didn't worked very well.
I drill holes on the back side of the lamp and sticked wooden picks to hold the strip in place as a backup solution.
Step 5: Mehr Licht
Here's the result. The cable is hidden behind the curtain.
The room was lacking light on this side and I wanted indirect lighting.
This project could be simpler without the use of epoxi glue.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Thank you everyone for your comments and advices.
    As a tip I usually use a clear UV Stabilised Resin from Barnes to bed my led strips into the c-channel. It provides the required hold strength to keep the LED strip fixed, doesn't cloud over time and is waterproof all in one.
    Very cool!
    This is a great idea. I'm going to try it today. I have been trying to think of a way of getting a nice indirect LED light together. What I'd not thought of was using a c-shaped channel. I've got some unistrut in my lab that will work great. Thanks.
