Wall Mounted Computer
5,281
82
11
Posted
Introduction: Wall Mounted Computer
Make a beautiful wall mounted laptop
Step 1: Materials and Laptop Disassembly
  • laptop
  • screwdriver
  • poster board
  • hot glue
Since there are many types of laptops i will not post how to disassemble it.
what you want to do is to find a disassembly guide for your laptop and follow the guide.
Step 2: Moving the Lcd Cable
move the cable down a bit so you have more room to work with
Step 3: Set It Up
plan out the components on the poster board
Step 4: Finished
Hot glue it down and you are done.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Trash to Treasure
      Trash to Treasure
    11 Comments
    @SimonF7 If you knew anything about computers, then you would know that a static shock from your finger can screw up the entire motherboard and make it useless
    This is a great show of curiosity. In college, I used to hang old circuitry on my dorm room wall as art pieces. Then I got the bright idea to start putting working circuitry on the wall. I had a working radio with cd player. It was always funny watching people freak out when they realized the cd player worked with the cd spinning on the wall.
    How does the functionality improve? Not trying to put you down, just curious as to what you get out if this
    The cooling would increase because its not stuck in a box, so less thermal throttling would occur and the performance could increase. Just a theory, not an expert.
    Cooling can improve for a laptop because those things are just as much circuitry as possible shoved into a tiny little box, but only if there is still forced air (like the fan) over the CPU.
    A lot of PC builders will leave a side off of their tower for the same reason, but that is usually a bad idea as it screws up the air flow designed in the case.
    The cooling improves and i dont have to look at a laptop with a ceacked case
    You realize if you touch this whole it's on the wall and happen to deliver a static shock, the computer is pretty much gone
