Remove these ads by
Signing UpStep 1Get the materials
4x8 sheet of 9/16" chipboard - $11
4x8 sheet of 1/8" clear plexiglass - $53
4x8 sheet of 1/8" masonite - $11
three 24" "preheat" fluorescent bulb holder thingies - $9.50 each
three 24" fluorescent tubes - $4 each
three power cords with no ends - $6 each
three switches - i used cool looking push button ones - $3.80 each
three packs of hook closer thingies(eye hooks with little arms) (3 per pack) - $1 each pack
four packs of 1" hinges (three per pack) - $1.75 per pack
three packs of 1/4" weather stipping (17') - $1.87 per pack
two foam brushes - $0.75 each
three 1x2x8' pine boards - $3.40 each
one tube of construction adhesive - $2.30
three sheets of rice paper (i didn't look at the size) - $2.50 each
two packs of 50' picture hanger gear (two sets of eye hooks and hangers plus wire in each pack) - $2.25 each
three bags of 1" corner braces (three per bag) - $1.75 per bag
adhesive felt pads - $3.28
total - $195.04
that's a lot of dough! but it really makes pretty much four lightboxes of this size. you'd just need a few more hinges and whatnot. there's enough of the big stuff (plex, masonite, chip board) for four.
LEDs would definitely be an awesome addition to the box. In fact, if I had to build these again, that's probably the route I'd go. You could get a lot nicer light with less power and thinner box.
Hope to see you there.
Home Repair, Refurbishment, and New Projects
I've been faced with this decision before and recalled that foil is generally considered a poor choice due to both its % reflectivity and the difficulty in keeping it flat and installing it. Checked 2 sites on the net and got these numbers (na=no additional info). Flat white paint is probably easier to apply and isn't electrically conductive. Yeah it takes a while to dry but that just gives you more time to think about girls (or boys)!
% Reflectivity
Mylar: 90-95/90-95
Flat white paint: 85-93/75-80
Semi-gloss white: 75-80/na
Gloss white:70-75/na
Flat yellow: 70-80/65-70
Aluminum foil: 70-75/60-65
