Step 6Assemble the box
i predrilled these marks with a tiny drill bit so that i had a starting point. then i set the box pieces on edge, lined the corners up tight and predrilled again into the "receiving" piece. i'm sure that there's a better way to explain this. hopefully the pictures help. once i had a hole drilled, i'd drive a screw in. i would only predrill and screw one hole at a time to make sure that the joint was tight.
once you go through that process a few times, you'll end up with the box frames!
Add Comment
