Wall mount your Wii for next to nothing. by cdach2000
Step 6: Hook up the cables.
Your almost there.  Obviously you will now need to re-hang TV on the wall.  Now be very careful.  If you drop it, there is no telling what the wife will do.
Slide the Wii into the sling.  Hook up all of the cable connections.  Plug the power pack in behind the TV and tuck it behind the TV as well.  I mounted my Wii sensor bar thingy on the bottom of my TV with the double sided sticky pads and it seems to work fine.  Your results may vary.  You may need to mount it on top.   Make sure to change the console's settings so that it knows whether the sensor bar is on top or bottom of your TV .
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
