wall screws | Magnets from old harddrives | piece of wood | knives = wall mounted magentic knife block
Remove these ads by
Signing UpStep 1Behind the magic
Mortice out the back of the knife block, to 1/4" from the block face.
I hung it with 2 screws, the screw head hooks were washers till I went at them with a hacksaw. Glue in place. Tip: use a sheet of paper against the back of the block and mark where the screws need to go, then place the paper against the wall and use a level for once.
Do not put up in an earthquake prone area, keep out of the reach of children, etc etc.
5-10 years ago i had no problems with drilling / bashing / warping my way into a hdd just to take it apart, they were entirely metal then, and the metal platters made nice windchimes, nowadays your looking at glass platters etc, you bash your way into one of those and your looking to be rubbing out glass dust of your eyes for weeks once you crack it open. (over dramatization but you should get my point)
Of course, if the back was recessed a bit above the magnetic strip, the wood wouldn't be in contact with the carbon steel, and rust wouldn't ensue. Even oiled wood traps moisture.
Knife blade pointing down means that your hands are above the action, but your feet are more likely to be under when reaching.
Depends on where the strip is located: above or below your shoulders (approximately).
Low mounting means you want the tips pointing down, so they won't fall far, and the countertop "shields" the tips.
High mounting means you want the tips upwards, so you are less likely to reach back and slice your fingers open. If they fall, they're falling a greater distance, and the handles will hit first.
My take on the issue, anyway.
