Wall of Memories
Published
Introduction: Wall of Memories
About: Wow! Such science! Very lab! So research! Many awesome!
That's a cool & easy way to organize a lot of photos. Are you ready to create your own wall of memories?
Step 1: Rope Holders
The idea is simple: to build a support using steel wire rope. In my project I bought:
  • 2 meters of steel rope, with diameter 3mm (5€)
  • 6 fasteners (3 €)
  • A bunch of little magnets from ebay (3 €)
I had already some thin steel wire, from an hardware store you can get it for 1-2 €.
First of all, decide the length of each rope holder. In my project, I made three pieces of 50cm and three pieces of 60cm. Prior to cutting the rope, put some electrical tape around the cut point: this will prevent the wire rope to unfold. Cut the rope using a plier.
To make a single holder, take a piece of steel rope, make and close it using the fastener. Fasten the nut (you can do it using only your hands) almost until possible. Take ~10cm of thin steel wire, slip one end and screw it around the rope. This will hide the tape, and add a nice decoration.
Step 2: Hammer Time
I've decided to hang the photos over my bed; the distance between the nails is 19 cm, slightly more than the usual photo width.
Step 3: Combine
Take your photos, and divide them by topic. Hang each one using a small magnet.
Step 4: Admire
(You'll notice that the rope are not perfectly straight. Well, I like it more this way. If you prefer you can easily put some weight to end of each rope.)
Take a pause to admire your work. Now it's time to think the new memories to add to your wall.
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    2 Comments
    That turned out to be a great way to display your pictures!
    Thank you! ^^
