Wallpaper Cards
Introduction: Wallpaper Cards
In this tutorial you will learn how to elegant cards for every occasion in a personalized yet low cost way.
Step 1: Supplies
The most important supply is an old wallpaper sample book you can find at your local paint store usually for about $1.  Next, you will need cardstock or just some type of paper/construction paper will work. Any type of adhesive will work, I like to use glue sticks and/or modge podge. Xacto knifes work well for cutting out specific shapes from the wall paper book, but scissors are fine as well. I usually like to use paint pens as well, either to personalize your cards or just to add design.  Watercolor can be nice if you are feeling ambitious.
Step 2: Paper Product Options
Tissue paper, pre-made blank cards, and laminating sheets are some materials you can considering using as well.
Step 3: Shapes and Patterns
You can mix and match by cutting out shapes from your wallpaper samples such as trees and hearts. Or you can find pictures/parts of your wallpaper that you like and incorporate those.
Step 4: Example 1
In this card, I used modge podge to adhere tissue paper to cardstock. Then cut out this cupcake shape from three different wall paper samples.
Step 5: Watercolor Example
In this card I layered wallpaper, tissue paper, and watercolors. I've also added mini-rhinestones (with superglue) which can be nice.
Step 6: Pre-made Card Sample
This is an example where I have used a pre-made card. I just cut out the fleur de lis shape from a wall paper and inserted it in the cut out section of this card.
Step 7: Alternate Materials
In this example I have actually used a very thin piece of wood purchased from a hobby store (usually used for making plane models) and decorated it by using paint pens.
Step 8:
Hopefully these examples have inspired and help you make your wall paper card creations, perfect for any occassion and easliy personalized.
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
