3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Walnut Kalimba Necklace (Semi Acoustic)
We at NakagawaGakki are always looking at new ways to make sound more portable and interesting. The idea of a necklace capable of rockn da house was the inspiration.
If you have time on your hands and the nuts, then you can make one too.
You will need:
Walnuts
Small handsaw
Sandpaper
Wire
Hair pins
3mm thick hardwood
wood glue
Hand drill
Contact mic (if you want to make your necklace LOUD)
OK lets get started...
(If you want to skip all of the following steps then you can always visit our Etsy Store to purchase one of our exquisite Kalimbas!!!)
Step 1Split and flatten ya nuts!
Ok, easy enough you say, but first you will have to decide if you want to crack them or cut them.
You can try cracking a few with a hammer, a nut cracker, your hand or your head but you run the risk of not getting a clean/straight line and/or injuring yourself.
We prefer cutting them down the seam with a hacksaw or small hand scroll saw. If you decide to do it with heavy machinery the normal precautions apply.
Please be careful of your fingers.
Take a break, eat contents of opened nut.
Next is to make the surface flat.
Lay out some medium grit sandpaper on to a flat surface like a hard table top.
You can use a little doublesided tape to keep it from slipping.
Slowly run your walnut across the sandpaper in a straight line away from you.
After a short time (walnut is quite soft) the surface should be as flat as your table...
It might be good idea to clean out the refuse in the interior of the nut unless you want your kalimba necklace to double as a maraka.
Hey come to think of it, thats a great idea!!!
11 comments
Apr 25, 2010. 7:53 AMtudgeanator says:
Having finished making mine a while back (no pics - my camera is broken) I discovered that the walnut itself does most of the resonating itself, rather than the plate of wood at the front, because I used wood that was far too thick as I had no thinner stuff, which means if I hold it like you do in your video, I get no sustain at all. But if you hold the walnut to your mouth and play it, you get loads of sustain, it's louder, and you can alter the sound with the shape of your mouth! Thanks so much for the 'ible, I'm onto making a more traditionally sized one using a coconut.
Apr 3, 2010. 6:24 AMtudgeanator says:
 Awesome 'ible, i'm definitely making one! But, as far as I can tell you missed out one small step - you didn't mention putting a whole in the front plate, but it appears on the front plate in your pictures.
Mar 13, 2010. 6:14 PMnepheron says:
WOW!!! You inspired me to make my own!
I got the piezoelectric disk from Dollar Tree. It was inside an "IntrudAlert" burglary alarm
..the alarm function is a failure, but it makes a mean pickup after some dissecting! It even come pre soldered, with wires attached and all!
Here are pictures of the one I made:
Mar 9, 2010. 7:58 PMnoahlankford says:
I wonder if there are other types of nuts you could use for this? But still a great gift idea!
Mar 10, 2010. 8:59 AMsnapel says:
 Coconut? I don't think there's any bigger nut. Or any other with a shell.
Mar 10, 2010. 8:56 AMomnibot says:
Yes, I'd suggest coconuts but only someone with truly fiddly hands should try sunflowerseeds.
Mar 9, 2010. 2:29 PMnickodemus says:
I like the idea, although it looks a bit hard to hold and play. But aside from that, great job on the 'ible.
Mar 9, 2010. 12:51 PMcowscankill says:
I love that sooo much, because of it's size and what it is made from :D
I just need a walnut...
Mar 9, 2010. 12:42 PMzascecs says:
A little out of tune, but still, this is pretty cool! I like how you can plug it in like a guitar, gee, my brother would just love to have one of these!
Nut in disguise!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:NakagawaGaki
