Introduction: Warfire's Knex Rbg Pistol
This gun is my first instructable so please dont post rude comments.It shoots an elastic around 25-30 ft. If enough people like it i will post more guns like it or you could recommend a gun for me to put on instructabls. Good Luck!
Step 1: Piece List
This will save yourself time for finding all the pieces before you start building.If you have trouble tell me thanks.
Rods:
Green-13
White-12
Blue-18
Yellow-4
Bendy Orange-2
Red-2
Connectors:
Yellow half circle-22
Purple piece that attaches to blue circle-8
Orange-8
Black Y-2
Green-4
Red-3
Grey Connector-2
Snowflake-3
Step 2: The Handle
This handle is very strong and comfortable.(Based on Gorkems Sniper,Thank you)
1.Make three of these
2.Make these, one has a orange connector, one has 3 blue rods for extra.
3.Attach the three pieces like this(dont mind the yellow rod its for a better pic)
4+5.Heres what the final handle look like.
Step 3: Trigger System
Im pretty sure i have seen this type of trigger system for other rbgs but this is my variation of it, if not tell me.
1.Make two of these.
2.Make one of these(white snowflake with a blue rod)
3.Put all of them together like this.
4.Actual trigger part.
5.Put a blue rod through the orange connector on the trigger, attach like so.
6+7.Put the trigger system on to the handle like this.
Step 4: The Barrel
1.Build two of these.
2.Put them together with a yellow rod.
3.Attach them together wit ha white rod.
4.Pretty self explanatory
5.This one is self explanatory too.
7+8.This is how the barrel should look like when its finished.
Step 5: Finishing the Gun
1+2.Sorry guys you will have to take off the yellow rod on the red connectors, it needs to be threaded through this, snap it on.
3+4.Here is how this is connected.
5+6.(Optianal)This is sort of a decoration that gives more stability,make two of these.Attach like this.
Step 6: Loading and Firing
1+2.Put an elastic on the trigger like this.Other end goes here.
When you are loading put the elastic on the end, on the yellow half-circle.Pull it back and slip it onto the white snowflake.(p.s. i think it works better if you put it on the v part not the part where you connect the rods.Your finished congrats.
