Warm Flannel Crib Sheets and Bonus Burp Rags
Introduction: Warm Flannel Crib Sheets and Bonus Burp Rags
I'm about to have my first baby soon and have been looking at all of the cute sheets that you can buy...however cute sheets can be expensive!  Also you might not be able to find something to your specific tastes.  I'm going to show you a really easy project that will create a fitted flannel sheet, as well as two burp rags...with no waste!
Step 1: Pick Out and Wash Your Fabric
For this project you need the following:
2 Yards Flannel
Roughly 80" of 1/4" wide braided elastic
Tape Measure
Sewing Machine
Optional: Iron
Head to your favorite fabric store and purchase flannel in 2 yard increments.  The fleece should be as close to 45" wide as possible.  Flannel is generally a couple inches shorter because of how it is made.  I purchased 4 types because I wanted to make 4 sheets.  Also purchase 1/4" braided elastic.  I bought 8 yards.  If you can you want to get as close to 80 inches per sheet...since I'm being frugal I just cut 8 yards into 4, but if you're buying by the inch, get 80 inches for each sheet you want to make.
Try to hit a sale, fleece can be 5 or 6 dollars a yard but I got this particular fleece for $2.50 on sale.  Since A crib sheet is about $15-$20 for a cute design, you want to try to keep your costs down to make it worth your effort...that is if you're trying to save $.  If you're just trying to make cool sheets that go with your particular decor, go wild :)
Wash  and dry the flannel.  This is VERY important. You don't want to go through all this effort and have your sheet shrink after you make it!
Step 2: Fold, Measure and Cut
You can optionally iron with a warm iron if you have tons of wrinkles, but I'm pretty lazy so I skipped this step.
Generally when you sew you cut off the selvage edge, that's the edge where there's generally writing, or it's white.  I left mine on because when we fold up the edge you won't see it and since flannel is not 45" you need all the extra surface you can get.
Fold your fabric in half and then half again so all of the corners of the fabric are together.
Measure 8 inches in each direction from the corner and mark with a pin.  This creates a square in the corner.
Cut out the square and you have now cut out all 4 corners at the same time.
You could optionally measure this out 4 times and cut out each corner, but this works really well as long as you have folded your fabric neatly.
Make sure to save your corners, these are going to be used for the burp rags later.
Step 3: Pin, Sew and Zig Zag the Corners.
On all 4 corners, connect the cut edges so that the "wrong side" faces out and pin.
Straight stitch it and then go over the very edges with zig zag.  This will help keep the corners from fraying when you wash.
This makes the corners of your fitted sheets.
Step 4: Zig Zag or Serge the Rest of the Sheet
Zig zag around the edges of the entire sheet.  This will keep you from fraying when you wash the finished sheet.  After I did this I trimmed off any loose threads.
Step 5: Pin and Sew Around the Edges
You can either iron the edges down just slightly more than a half inch, or you can just pin them down.  I actually only used about 5 pins and then kept pinning as I sewed around the edge.
Make sure to leave a 3 or 4 inch gap at the end so you can thread the elastic in.  It's easiest if you start in the middle of one of the sides of the sheets, versus a corner.
Step 6: Insert Elastic and Sew
Using a safety pin, pin one end of the elastic and start scrunching it through.  To make sure that you don't lose the other end, pin it down.  Keep scrunching and moving the fabric over the safety pin.
This will be hard to go around the corners, which is why I noted to make your hem larger than 1/2 inch, so that the resulting hem has a 1/2 inch space.
Once you have gone all way through, overlap the elastic and zig zag it.
Then pull the elastic into the hem and finish the hem edge.
Voila!  A fitted Crib Sheet!
Step 7: Burp Rag
For the burp rag you can trim off the selvage edges, or leave them on, just make sure to sew in far enough to hide them.
Place the "right" sides of the fabric together.
Starting on one side (not a corner), start a straight stitch, go almost all the way around the square, leaving about 3 inches.
Turn it inside out.
Then do a straight stitch all the way around the piece, this will finish off the hole you left and make a nice edging.
Done!  You'll have enough to make two and you won't have any scraps left over!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
