3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wash Dog Fur for Spinning
Turn that smelly fur into soft gorgeous spinning fiber - without felting or matting it too much!
Step 1Bag it up!
Bag it up!
Place the fur into nylon mesh lingerie bags (or any netting-type bag that can be secured closed). Don't put too much in, you're going to need to have some room for water and soap to circulate. Gather a bottle of dish detergent (Dawn works well, but I prefer the industrial size gallon bottle of cheapo stuff) and head to a laundry tub or a bathtub.
18 comments
Jul 16, 2011. 4:38 PMesyck says:
I tried this just today! It worked amazingly, although getting enough hot water for the hair that I had was kind of an effort (I went to the local petsmart and asked their groomers for hair. They looked at me oddly, but gave me a garbage bag full, so...win.)
I actually wouldn't comment normally, except....well....I felt that I owed you an apology! I couldn't imagine this working as well as it did! :) It worked amazingly, and you're my new favorite person!
Oct 26, 2010. 7:25 PMteaellen 2003 says:
Since you must be so very careful to not "felt" the dog hair, could you actually felt it into something? I love to felt recycled wool and I have used wool yarn and then felted or actually felled the resulting piece. I also know that you can felt wool roving. I think that I will experimet with some fur from my furfaced daughter (an English setter named Lady with very long soft fur) and see what I can do. Who knows, we might have a new craft here. I have probably thrown away and vacuumed up enough fur to make lots of cool things. LOL!!
Aug 14, 2009. 12:50 PMjaevairny says:
Thanks for the idea. A question, though: I'd like to try doing this with fur from my cats, but I am concerned about allergies. I'm not personally allergic to pet hair, but I know lots of people who are. Will the washing process remove allergy-causing dander, or would I be walking around in my cat-fur (or, for that matter, dog-fur) scarf causing sneezes wherever I go?
Jun 15, 2010. 3:36 PMblodefood says:
I know this about cats: Most people are allergic to the dander caused by saliva residue. If the cat is rinsed with plain water, it does reduce allergic reactions. It is possible that dog fur does not produce as much of a reaction because a dog does not lick its fur the same way a cat does. Whatever allergens cling to the hairs are washed away in the washing process. Otherwise, there may be people who allergic to the hair itself. I am not so sure about that though.
Jun 16, 2010. 1:36 PMjaevairny says:
Great. Thanks for the response. I actually remembered this process the other day while I was brushing my cat and thinking, "I must have enough here to make a whole other cat. Or... maybe some yarn..." and then I saw your comment in my inbox. I will experiment - I'll enlist the assistance of my aunt who lives with us and is horribly allergic to cats but loves them and wants to be around them anyway so relies on antihistamines - I'll see how she reacts to some cat yarn once I've made it. Thanks! :)
Aug 29, 2010. 7:04 PMcchamlin says:
As a lifetime asthmatic and animal-allergic person, I can confirm blodefood's statement. The hair itself is not what people react to, it is the proteins in shed skin (dander) and saliva that adhere to the hair. If it is washed and clean as you are describing, it will be totally safe. (case in point, I can wear wool, even though I wheeze up if I spend much time around sheep)
Jun 15, 2010. 7:14 PMdombeef says:
How about the stubbly Jack Russell hair that sheds everywhere(I mean everywhere...)
Jul 15, 2006. 2:18 AMmeddler says:
Never thought of dog fur as material for spinning...Does it make a strong yarn??
Jun 15, 2010. 2:34 PMorksecurity says:
Well, I've been able to hand-spin fairly strong thin yarn/thick thread out of fur from a shorthair cat.... As said above, strength is greater with longer fibers, but if you spin it tightly enough before counter-twisting it into yarn you can build up a fair amount of strength.
Jun 15, 2010. 1:29 PMSinAmos says:
I was thinking about this for a while. My cousin is a groomer, so I figured she could supply me with the dog hair.:)
Jun 2, 2010. 1:19 PMdesya says:
 great I have a large Maltese... I am have started to collect her hair...
was not sure how to start turning into yarn
Apr 8, 2009. 5:15 AMBHB says:
Well done! A variant on that - I had 2 'lassie' rough collies and collected a lot of wonderful fluff which I washed in old tights, do you call them panty hose? This means it's cheaper than buying these special bags, and there is less bulk when drying them. You can spin them gently by the way, then sit them astride the washing line! Also, being less holey ( except for the reason you discarded the hose in the first place ;o) this method doesn't block your drain with loose hair! But beware clothes moths!!! They loved dog hair, washed or otherwise. I had to through lots away . Now I know that I could perhaps have salvaged something by putting (clean!) fluff into the freezer for 2 x 72 hour cycles, separated by a few days. I have an old one in the garage, since I have lots of textiles and a moth problem. It works! The first chill kills most moths stages, and the second kills larvae that hatch from eggs that survived. I gather that they are stimulated to hatch when they thaw out, so you can get the little darlings second time round. Don't delay the second freeze, as you may have larvae in there thinking it's spring time! Collie fluff spins beautifully
Jan 19, 2009. 11:50 AMHoaxinmi says:
Do you spin this yourself or have it sent out?
Jul 31, 2008. 1:02 PMBadgergirl says:
How would golden retriever fur work?
Apr 13, 2007. 7:03 PMcheekywombat says:
How strong the yarn is will depend on the length of the fur (longer tending to be stronger because it will twist around the other strands more) and the strength of the fur itself. If it's not strong enough by itself you could always spin it in with something like wool. I did that many years ago and wove the resulting yarn into shoulder straps for a backpack and they stood up to the job really well. The dog fur I used was a cross between English Sheep Dog and Poodle - long but really silky.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cobaltandindigo
I'm one of those people who just can't seem to stop learning - my never-ending list of interests include gardening, spinning yarn, fiber arts, high-fired porcelain ceramics, baking, cooking and woodwo...
more »
