Washable, Non-staining Stage Blood by the Gallon by RavingMadStudios
Featured
For our recent stage production of The Revenger's Tragedy, I needed to come up with an economical and effective way to make several gallons of realistic stage blood. Normally, I would have used one of the many corn syrup based recipes that have been popular for decades, but the Technical Director wanted to avoid sugary recipes due to the risk of attracting ants and other nasty creatures into the theatre.
In addition, the costume designer needed to be able to wash the blood completely out of the costumes between performances, the set designer wanted to prevent staining the set, and (since there was a possibility of splashing the audience) we needed to be able to assure audience members that their clothes would not be ruined. This pretty much meant no red food coloring could be in the recipe either.
Furthermore, the blood would have to be visible on both light and dark surfaces and work in several different delivery devices, including air cannons, pneumatic squibs, squeeze bulbs, blood bags and a trick knife. (For a truly excellent pneumatic squib, see Crosius' phenomenal Instructible here: http://www.instructables.com/id/Pneumatic-Squib-Tutorial/)
After experimenting with several formulas I came up with this one, which met all of the needs listed above very well, and only costs about $13.00 a gallon. Compared to some commercial blood at $60.00 a gallon or more, this is quite a bargain. If you need buckets of blood for any reason, give this a try.
Step 1: Gather Your Ingredients and Tools
For this recipe, you will need:
Ingredients:
Four 28 oz. bottles of orange or red ultra-concentrated dish detergent (the red frequently contains bleach - do not use any detergent with bleach)
One small bottle of ultra-concentrated Dawn dish detergent (blue)
1.5 cups of creamy sugar-free peanut butter (regular will also work)
One 16 oz. bottle of washable red poster paint
Blue washable poster paint
Black washable poster paint
Sugar-free chocolate syrup
Tools:
Large pot or mixing bowl
Gallon-sized jug or pitcher
Spoon
Strainer or cheesecloth
Funnel
Microwave oven
Step 2: Make the detergent base
Pour all four bottles of orange detergent into a large bowl or pot. Add 8 oz. of blue Dawn. Mix well. The blue detergent helps to tone down the orange color. When done mixing, you should have a big bowl of caramel colored goo.
Step 3: Nuke the Peanut Butter
Put 1.5 cups of peanut butter into a microwave-safe container and heat for 45 seconds at 30% power. You may need to adjust this based upon your microwave's power. You want to warm the peanut butter up, not melt it. This makes the peanut butter easier to mix in the next step.
Step 4: Add the Peanut Butter to the Detergent Base
Stir the peanut butter into the detergent mixture. This will take a while. To avoid whipping air into the detergent and making a big bowl of foam, use a spoon, not a whisk or an electric mixer. Keep mixing until you have a semi-smooth beige-ish glop. Some of the peanut butter will not combine, which is OK. We'll be straining out the undissolved peanut butter in a later step. Just try to get it as smooth as possible. The peanut butter adds opacity to the mixture and gives the red paint in the next step something to bind to.
Step 5: Make it Red
Dump in approximately 13 oz. of the red poster paint and stir until the color is evenly distributed. Make sure this is well-mixed, as the next step is to adjust the color to look more like real blood than the bright red paint.
Step 6: Make it Bloody
Add blue and black poster paint and sugar-free chocolate syrup to adjust the color of the mixture. The exact amounts will depend on the look you want, but 2 oz. of each is a good place to start. Mix well, then add more as needed.
If the blood is too red, add a little more blue, or a little more Dawn, if you prefer. If it needs to be darker, add more black. If it lacks a certain undefinable "richness", add more chocolate syrup.
When adjusting the color, go in small increments to avoid overcorrecting, mixing well at each increment. If you do overcorrect, try adding some of the remaining red paint left over from the previous step. If you have seriously overcorrected, you may be able to salvage the mixture by adding another bottle or two of orange detergent and more red paint. Otherwise, you'll have to scrap the whole thing and start over.
Step 7: Feeling the Strain
When you have gotten to a blood color you like, strain the blood into a gallon-sized container for storage, using a wide-mesh strainer or cheesecloth to remove the chunks of undissolved peanut butter. The mixture is very thick, so strain small amounts at a time. You will probably need to stop about halfway through to clean the strainer or replace the cheesecloth.
Step 8: Let It Bleed
The blood is now ready to use.
As I mentioned in the intro, this formula has been successfully used in a large variety of effect devices, including air cannons, pneumatic squibs, squeeze bulbs w/ tubing, blood bags and a trick blood-squirting knife. I had some initial reservations about foaming, especially in the air cannons, but testing showed that my reservations were unfounded.
For all these applications, we used the formula without diluting it. If you need a higher flow, the blood can be cut with water, but be careful not to use too much. Excessive dilution will cause the blood to tend to bubble and foam when ejected through the delivery device, and will probably require additional paint to maintain the correct color.
Step 9: Precautions
Just a few caveats regarding the formula:
1) Dish detergent is very unpleasant to have in your eye. Take care to avoid getting this blood in anyone's eyes. If the blood does get in someone's eye, flush immediately with water.
2) Likewise, do not use this blood in anyone's mouth.  That would just be nasty. For our recent production we needed several mouth packs, which we filled with corn syrup blood. The actors were grateful.
3) This formula, unlike the corn syrup stage blood, is very slippery. Walk with caution when blood is on a smooth floor. Do not use this blood on the floor in any area where an audience member may walk. A non-skid floor treatment is highly recommended, especially on raised platforms and angled floor surfaces. If sugar content is not a major concern, corn syrup may be substituted for up to half of the detergent, which helps to reduce the slipping hazard without a major impact on the washability.
4) Although this stage blood has been designed specifically for washability and stain-resistance, clean all costumes as soon as possible after exposure to the blood. If costumes cannot go immediately into the wash, rinse immediately under running water and leave to soak in a bucket of water to prevent the blood drying on the costumes. Dried blood is much more difficult to remove, and may stain permanently on certain fabrics.
5) This formula contains peanut butter, so inform all cast members and crew, and verify that no one who may come into contact with it has peanut allergies. If audience exposure is likely, a warning to the audience is also in order.
6) If left to sit too long, the blood will coagulate and potentially clog delivery devices. Clean all delivery devices after use.
1-40 of 42Next »
Steelersfan43 says: Mar 28, 2013. 7:22 AM
I was able to make pretty good fake blood w/ black and red tempera paints (tempera paint is washable) but it didn't look very realistic when it dried. I will try this.
bobdog says: Oct 26, 2012. 8:43 PM
Out of curiosity, has anyone tried almond butter or almond flour and say mineral oil to avoid peanut and rancidity issues? Walnut oil also keeps well IIRC. I wonder about bean flours too, whichever is lowest starch or highest protein/starh ratio. Any ideas?
ohiers1 says: Jul 31, 2012. 11:30 AM
This stuff is great! Works really well, and I got it out of a white shirt! Looks very VERY real!
gravityandmomentum says: Jan 14, 2012. 3:03 PM
That's a good recipe. There a lot of good free ones out there like that depending on your needs (washable vs. safe in the mouth).
Our company (founded in 2011) has a formula that is both washable AND safe on the skin/mouth. We have washed it out of white shirts, couches, wallpaper, floors, ceilings, suits, skin, etc. with just warm/hot water without any staining. It doesn't contain detergent, so it is non-toxic and safe in/around the mouth and skin. There's no chocolate or peanut butter, so no chocolate or oil stains. Stage managers love using our product.
Our Blood Jam product comes super thick. As is, it can be used as a stage make-up. It also has an indefinitely life span.
You can cut our Blood Jam down to whatever thickness you like with water, and it won't lose its color or washability. But, as soon as you cut it with water, bacteria could begin to grow so you have about a week lifespan at that point. Another good trick is to heat it up, which thins it out. As it cools, it will go back to its original thickness. This is great when we want a good oozing or splatter effect, but then as the scene goes on you don't want it dripping all over the stage.
We ship anywhere in the U.S. and are glad to provide any other tips or consulting to suit your needs.
Check it out at: http://www.gravityandmomentum.org/stage-blood/
-Gravity and Momentum, LLC
"Behind Everything You Do"
imbearly1 says: Jan 7, 2012. 3:06 PM
Many, many years ago there was a special effects company that made a completely non staining stage blood. However, they are no longer in business. The ingredients were microscopic beads of dark red plastic suspended in a clear liquid gel. The color never stained because the color was contained in the plastic. Would be great for some enterprising young person to recreate it. They would be rich. Just puting the word out there as there seems to be a great need for it in the theatrical community.
RavingMadStudios (author) says: Jan 10, 2012. 6:35 AM
I actually used that stuff for a show back in the mid-90's. The concept was great, and the blood looked pretty good, if a bit tempera-esque.
The issue I had with it was that the red microbeads got trapped in the weave of the fabric and wouldn't let go no matter how many times you washed it. The end result was not technically a stain, as the fabric was not actually colored by the blood, but functionally it was indistinguishable from a stain. I was a bit disappointed.
If somebody came up with a way to release the beads from the fabric effectively, it would be epic.
kturland says: Oct 22, 2011. 2:02 PM
hi my name is kylie and me and my friend were going to yuse your idea for fake blood for halloween cause ummm we were going to be vampire-wiches!
and i was just wondering if the blood mixture EVER expired!!!
THANKS!!!!
rheinze1 says: Sep 27, 2011. 12:31 AM
Someone shops at Walmart! <3
CODKING says: Sep 24, 2011. 9:51 PM
oh so tasty lookin lol jk
ozawatest says: Mar 15, 2011. 3:00 PM
Any thoughts on having lots of blood in a swimming pool (someone falls into a pool after being shot like crazy) without damaging the pool? The blood doesn't need to last long. Thanks!
blodefood says: Mar 3, 2011. 6:20 PM
Obviously because of the detergent content you would not be able to use this blood coming from the mouth. For that I suppose you would have to go back to the corn syrup recipe.
By the way, peanut butter is an ant attractant for some species of ants. I take it there would be enough detergent content to keep them away.
Eviil~~PikmiN__{7} says: Oct 30, 2010. 9:44 AM
why is the blood light coloured?
RavingMadStudios (author) says: Oct 30, 2010. 11:19 AM
The color balance of my camera is a bit off. It was darker in real life.
Eviil~~PikmiN__{7} says: Nov 5, 2010. 4:40 PM
oh ok... then this is a pretty great recipe
yespotato says: Oct 18, 2010. 5:22 PM
what if someone in the audience is allergic to peanuts??????? might want to think about befor u use it next. lawsuits could ensue.
RavingMadStudios (author) says: Oct 19, 2010. 7:24 PM
Yup. That's listed in the warning section of the Instructable, and lobby signs were posted.
yespotato says: Oct 20, 2010. 6:03 PM
ok good cuz i have a couple of friends that cant even smell peanuts. let alone touch it
hot kid 2099 says: Oct 15, 2010. 8:08 PM
(removed by author or community request)
featherwurm says: Oct 14, 2010. 10:36 AM
Oh where oh where was this tutorial when I had to produce so very much washable blood for Seven Crimes? I managed with a couple different mixtures (mostly detergent based), but this is by far superior (though so far as color went for us, the director had a thing for using red light on all bloody scenes which meant the blood usually needed to be deeply purple to show up, but that's not really an ordinary concern). This is great though, it seems like it really would create a nice visual mess without being a mess to clean up.
In other words, thank you. You are fantastic for posting this and I know I'll be using it in the future.
Is there any chance you could add a photo or photos from the production so we can see your handiwork in action?
RavingMadStudios (author) says: Oct 14, 2010. 12:04 PM
Thanks for the kind comments. Always nice to hear from a fellow wetworker. ;-)
Red light for all the blood scenes? That's a new one on me, although I have been known to strongarm a lighting designer or two in the name of good blood visibility. Usually for me, the lighting was more green than I'd like, which made the blood look like chocolate syrup. In this production, the lighting was never an issue, for which I am grateful.
Oddly enough, I was unable to be at the photo call for Revenger's, and so they didn't take any shots with blood, probably because of the cleanup issue. If I had known, I would have taken my own photos at final dress, but it didn't even cross my mind until it was too late. That is a mistake that I won't be making again....
featherwurm says: Oct 14, 2010. 2:03 PM
To be fair the red light did look cool in that context, but it nearly 100% washed out blood-colored blood. This was about as light a color as it could go, http://www.featherwurmgraphics.com/Theater%20%28Costume,%20Puppets,%20etc%29/Seven%20Crimes%20%28Add%20More%29/Razor.html as you can see in the more regular light in the last couple photos it's really pretty purple.
Aw dang that sucks, and I know the feeling, but there's always the next one... there's always a need for blood!
M4industries says: Jul 22, 2010. 7:57 AM
To make the thumbnail more interesting, make the blood arterial and dark. This is to be more anatomically correct.
RavingMadStudios (author) says: Jul 22, 2010. 12:00 PM
We chose to go with a more "cinematic" look for this production, as opposed to purely realistic. The blood wasn't as ketchupy as the photo makes it look, though.
M4industries says: Jul 22, 2010. 1:46 PM
At least make a latex wound, it just looks like a spill. But I still like your method.
Valeil says: Oct 7, 2010. 3:04 PM
Maybe it was vomited?
romanceblood says: Aug 18, 2010. 9:27 PM
didnt know i'd find this on here, but btw i still have blood splatters (yes stained) into my khaki cargo pants from when I saw RT at GSU.
RavingMadStudios (author) says: Aug 19, 2010. 4:36 AM
Sorry about your pants. I haven't heard of any other cases where this blood left a stain behind, including the wedding dresses we used in the show. Very odd. Swing by the Theatre cookout this Friday afternoon, and I'll buy you a cheeseburger by way of apology.
keithwarburg says: Jul 23, 2010. 6:51 AM
OH, very much enjoyed it. See you around.
keithwarburg says: Jul 22, 2010. 10:01 AM
Our campus did a production of tRT in october, and it was incredible bloody. I left with small amounts of this stuff on my face, hands, and everywhere else in range of a headshot. :)
RavingMadStudios (author) says: Jul 22, 2010. 11:36 AM
Hey, that's when ours was. You don't live in Georgia, do you?
keithwarburg says: Jul 22, 2010. 6:44 PM
I do! It was at Georgia Southern.
RavingMadStudios (author) says: Jul 23, 2010. 5:02 AM
That's the one. Glad to know there are other Instructables folks here in town. You make the fourth one I know of (counting me), and RedHandFilms has graduated and left, so he doesn't count anymore.
Anyway, I hope you enjoyed the show,
abbyholverson says: Jul 21, 2010. 8:25 PM
Awesome... great instructable. (And really, any show where the there is so much blood that the audience gets sprayed = best thing ever) I know I've made similar blood with liquid laundry detergent... never thought of the peanut butter, though, that's great.
RavingMadStudios (author) says: Jul 22, 2010. 6:43 AM
Thanks very much! I've been playing with blood recipes for (mumble mumble) years now, and I'm pretty pleased with this one. I'm not sure where the idea for the peanut butter originated (probably an edible formula), but it does really help a lot with visibility and consistency.
yoyology says: Jul 21, 2010. 2:46 PM
I can't resist a theatrical quote: "We’re more of the blood, love, and rhetoric school. […] I can do you blood and love without the rhetoric, and I can do you blood and rhetoric without the love, and I can do you all three concurrent or consecutive, but I can’t do you love and rhetoric without the blood. Blood is compulsory — they’re all blood, you see." Great instructable. Makes me want to see the show!
RavingMadStudios (author) says: Jul 21, 2010. 7:48 PM
Hee hee hee. Thanks very much! Gotta love Stoppard.
moo of the cow says: Nov 25, 2009. 11:12 PM
how long will the blood last? will it go rancid????
RavingMadStudios (author) says: Nov 26, 2009. 5:00 AM
Honestly, I have no idea. We ran through it pretty fast, so it didn't really sit around long enough to tell. I'm sure that the peanut butter will eventually go rancid, but your guess is as good as mine as to how long that would take (weeks or months is my guess, fyi).
I did discover that if you refrigerate the blood, it gets really super-viscous and separates a little, but a few hours of thaw time at room temp and a shake or two fixes it right up. If you don't mind having to warm the blood up before using it, this would probably extend your shelf life.
Prof. Yummy says: Feb 3, 2010. 9:27 AM
If you happen to have any laying around, you can add a little methyl paraben to help keep it from going bad.
RavingMadStudios (author) says: Feb 3, 2010. 3:40 PM
Good to know. I'll try that next time I have a show that demands a large quantity of blood.
1-40 of 42Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
