loading
Washer hho generator
WARNING EXTREMELY EXPLOSIVE IF NOT USED CAREFULLY
it doesn't always generate a lot of hydrogen gas so tinker around
This is my first instructible let me know how it is
Step 1: Materials
for this project you will need
5 2 inch washers
4 smaller washers of any size(they have to be smaller)
1 3 and 1/2 inch by 1/4 inch bolt
matching wing nut
blue tape
2 to 3 wires
2 to 3 ring connectors
pliers
sand paper
power supply (I used a car battery charger)
Step 2: Prepping
To prepare the washer you must take the sand paper and scrape on all the washer in a x pattern to get the most surface area for electrolysis.
then take your wires and connectors and crimp the connectors on the wires(duh)
wrap your bolt with the blue tape.
Step 3: Assembly
first put one of the wires on the bolt.
place all the washer on the bolt in an alternating big small pattern
W BSBSBSBSBSBSBSB W
Add the second wire and wing nut and put it in your water
hook it up to the power supply and use it
Step 4:
<p>this project cannot work because if you assemble as instructed there will be a dead short as none of the washers are insulated from each other only from the bolt </p>
About This Instructable
4,318views
26favorites
License:
More by mcevanlong:Washer HHO Generator
Add instructable to:
