loading
Step 8: All Finished! and Rules
Finally, just spray paint the galvanized washers two different colors (Red vs. Blue).
And play Washers
Rules:
Two teams of two (red vs. blue);
Set boxes approx. 12 ft apart (may offset boxes)
One person from each team throws washers into box alternating turns
Scoring:
Washer in box or on top rim of box = 1 point
Washer leaning on cup on inside of box = 2 points
Washer inside of cup (leaning or flat) = 3 points (a cupper!)
Every washer counts, Colors cancel out.
First team to 21 points wins.
Scoring Example One: 1 blue in cup; 1 red in cup, 2 red in box  Score = 2 points for Red Team.
Scoring Example Two: 1 blue in box, 1 blue in cup; 2 red in box, 1 red leaning on outside of cup  Score = O points, round draw.
Doesn't having the brackets inside the cup effect the game?
<p>You can also install a PVC flange to the bottom with nuts and bolts, and then glue the PVC pipe in the flange with PVC cement. I'd cut a whole in the carpet and place it over the pipe so the thickness of the carpet does not cause the pipe to be higher than the sides of the box. It should be at the same height. Good instructions though!</p>
Not noticeably. In recent incarnations I have just used Gorilla Glue and if seems to be holding up fairly well.
Are the scoring instructions correct? <br> <br>&quot;Scoring Example One: 1 blue in cup; 1 red in cup, 2 red in box Score = 2 points for Red Team. <br>Scoring Example Two: 1 blue in box, 1 blue in cup; 2 red in box, 1 red leaning on outside of cup Score = O points, round draw.&quot; <br> <br>Shouldn't 'Scoring Example One equate to 4 points for Red Team? <br>Scoring Example One: <br>1 blue in cup (3 Points) [Cancels out] <br> <br>1 red in cup (3 Points) [Cancels out] <br>2 red in box (4 Points) <br>Score = 4 points for Red Team. <br> <br> <br>Shouldn't 'Scoring Example Two equate to either 3 points for blue and 4 points for Red....or just 1 point for Red? <br>Scoring Example Two: <br>1 blue in box (2 Points) [Cancels out] <br>1 blue in cup (3 Points) <br> <br>2 red in box (4 Points) [Cancels out only 2 points leaving 2 points to Red] <br>1 red leaning on outside of cup (2 Points) <br> <br>Score = 3 points Blue, 4 points for Red <br>or <br>Score = just 1point for Red
You can score anyway you'd like but my example of how we play follows: <br>Washer in box or on top rim of box = 1 point <br>Washer leaning on cup on inside of box = 2 points <br>Washer inside of cup (leaning or flat) = 3 points (a cupper!) <br> <br>You might be confusing a leaner against the outside of the cup (2 points) verses just 1 point for getting it in the box (no leaner).
Ok. I misread one of the scoring rules. <br>&quot;Washer leaning on cup on inside of box = 2 points&quot; <br> <br>I read this as &quot;Washer leaning on cup [OR] inside of box = 2 points&quot; <br> <br>Your scoring is correct. Sorry for my confusion.
where exactly did you find your large washers? the best I could find was 1.5 inch diameter galvanized, but they weren't as heavy as the ones you have look to be.
I found them at Lowes or Home Depot.
alright cool. thanks
I like this. :)&nbsp; - Am I understanding the scoring, that when you say colors cancel out, you only keep track of how much lead there is by whichever color rather than a total score?&nbsp; I think that would be another way to say it.&nbsp; Nice sturdy construction for a game.<br />
Very nice! Is 14x14 the outer dimensions of the 2x4 box, or the inner (the target area)?
The outer dimensions and the bottom plywood piece are 14&quot;X14&quot; . The would make the inner target area about 12&quot;X12&quot; (I say <em>about </em> because the 2X4's aren't exactly 2X4).<br/>
I had one of these made a while ago, but I do like your addition of the latch and handles. The two main differences between mine and yours is that I did not use the artificial turf on the bottom, and I used a stainless steel cup that I made at work. The pros and cons are that without the turf it is more difficult to keep it in the box, but the turf protects the wood from becoming easily damaged. And for the cup, a stainless steel cup won't break as well as gives a nice ting when you hit the cup. Aside from that the rules that we generally play are pretty close to yours, except if nothing is made into the box/cup closest washer gets one point, in box is two, and in cup is three, and like points cancel out as well.
isnt it also called astro-turf?
That's actually a brand-name that's turned into generic, like Velcro and Duck-tape.
=) oic, thanks for the info, another would be coke, and ski-doo<br/>
I love Washers. Great set. These cost a lot of money (at least $100) at the store and they are great for tailgates! Thanks for sharing.
played it at a party oncfe, with a bunch of reletives of a friend, and we stood 20ft back, marked by string, tied to 2 boxes. 2 washers each, per 2 people on a team, one person from ewach team stodd at each end, threw them, and the team members on the other end picked them up and threw them again
I really like the way you designed the latches to make it so easily portable and contained. Good idea. The only thing I would have done differently would be to make the artificial turf level with the opening of the PVC. On a 'regulation" (yes, there is such a thing) washer pit, the hole (which is 4 inches in diameter) is placed in sand and the opening is flush with the surface. This allows a little different game play by letting the washers slide into the hole instead of a 'nothing but net' approach. It also allows for "hangers," which are three points. "Cuppers" are 5 and closest to the cup is 1.
My grand parents have something like this, but they call theirs the holy board :P you have to stand ten feet away and toss a waher at a board with three holes and try to get it in the middle hole....its hard>:-O
Be careful with the dimensions in the material list, the inches and feet symbols are a bit mixed up. But you're smart, you'll figure it out though.
Good Instructable! I have a similar set but we used coffee can instead of PVC and sand instead of the artificial grass.
My relatives have this at their ranch. It's about as redneck as you can get- real big washers, coffee can, 2x4's, lol. It's fun. Nice set you have there though!
Nice job! My dad made a set a lot like that. We never had the idea for a handle on it though.
That's a very nice washers set there. I really appreciate it when people take the time to make a dedicated set for a casual game.
About This Instructable
77,737views
210favorites
License:
More by the_Magnificent_Macak:Block Base for a Fire Stand Washers Game (or Urban Horse Shoes)
Add instructable to:
