3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Washing Machine and Dryer pedestal / Stand: A DIY Happiness!
We all know washer and dryer pedestals are VERY expensive and are ridiculously priced. You can certainly buy another washer for the price of the two pedestals; or perhaps a new refrigerator! This instructible shows you how to make yourself a cheap pedestal or stand for your washer and dryer.
The advantages of having a pedestal or stands for your dryer and washer is that you eliminate the need to bend over to pick up your laundry. Also you can place items under the pedestal such as soap, laundry detergents, etc. The pedestals are a practical accessory for front loading washing machines and dryers.
Step 1Materials
Materials
Materials:
Plywood (the thicker the better. mine is about an inch thick)
2" x 4" wood
Drill or hammer
Saw
Screws or nails ( 3 inch screws/nails, 2 inch screws/nails)
Glossy paint
All items can be bought at your local hardware stores. I got all these at home depot. The plywood cost $15 since it was very thick. The 3 pieces of 2" x 4" x 10" cost $2.35 each.
Since I already measured the base of both my washer and dryer, I went a head and had home
depot cut the plywood for an extra .15cents per cut thus eliminating back pains and muscle
sore from cutting the plywood myself. I highly recommend doing this.
54 comments
1-40 of 54next »
Apr 12, 2012. 12:26 PMKangrrl says:
If you have small children, you MUST anchor these machines to the pedestal and floor. A young child will hang off the door if left open. In fact, all large furniture in your home should be anchored to the wall!
Apr 26, 2010. 6:52 PMbanker says:
Why do you need a pedestal?  Can't you just sit them on the floor?
Feb 4, 2012. 11:15 AMosandra51 says:
When you have back problems, raising your washer and/or dryer makes it so much easier to get close out of the dryer.
Apr 12, 2011. 10:41 PMjstoner says:
also if your basement is prone to flooding, it's nice to elevate your washers (and every damn other thing in your basement.)
Apr 30, 2010. 11:29 AMgnawlej says:
Raising front loaders makes it easier for tall folk like myself.
Aug 6, 2009. 9:50 AMlgarcia323 says:
when the washer spins are the pedestals strong enough to handle the vibration? is there any issue with this?
Aug 23, 2011. 12:35 PMjeffeb3 says:
I made something similar, and the concrete floor they are on means they shuffle around a little bit. Occasionally they will get close to each other and start making a lot of noise. I think I just need to put something soft (like carpet squares) underneath to dampen that energy.
Aug 11, 2011. 9:44 PMdroopycom says:
Did you try to screw your pedestals to the washer ?
The pedestal you can buy are normally screwed at the bottom of the washer.
Aug 5, 2011. 12:43 PMiamnos says:
I spoke with a repair man after buying our new front loading set about building my own pedestals. His advice... "Do It". They can be made very easily (as you see in this Instructable), and much cheaper than the commercial ones. Not only that, but with some 3/4" or 1" plywood and some 2x4s, it will actually be more sturdy than the commercial ones. One thing our guy did recommend, especially on a wooden floor, is to screw the pedestals to the floor.
I'm planning on building very similar to what was posted here, except that along the back, I'll put a 2x4 horizontally along the ground. The legs will then be between the top 2x4 rail and this new bottom 2x4 rail. I'll then attach that bottom rail to the floor with long screws, hopefully into the floor joists, which will make them very solid.
One other suggestion he had was once you have the washer perfectly leveled, raise the front end up slightly, about 3/8". This will keep the weight towards the back of the washer reducing the strain on some parts, and making it last longer.
Mar 12, 2011. 7:41 PMbdizon says:
This looks like a great solution. Have you heard anything about this design withstanding time?
Feb 25, 2011. 2:37 PMghughes32 says:
Does anyone know if making your own pedestal might void any warranties?
Thanks
Nov 14, 2010. 8:59 AMstubeanstu says:
raxel,
this is great! thanks so much. I just built one for a new washer and so far it is going great. I doubled up the 2x4s on the legs so I have an inexpensive 4x4 for the legs.
blessings
Jul 27, 2010. 7:52 PMxhead says:
I used this design to build a double-wide pedestal a couple months ago. I used a 4x4 for the front middle leg. It's quite stable. And about $50 in materials, and I got Home Depot to do the cutting (they make a much nicer straight line than I can with a skill-saw). It took me one evening to build and another couple hours to put two coats of paint on it. This is a great site. Thanks for this write-up.
Jul 14, 2010. 3:33 PMmarkkussusa says:
Hi, I'm about to make mine, too. where'd you get 1" plywood??? all the storres around sell only 3/4" !!!
Jul 14, 2010. 8:32 PMmarkkussusa says:
went to Home Depot... I'm so furious! (not really, but annoyed for the waste of time) ... They messed up the cutting! OK, if they were an inch or 2 off... I would have offset that during while assembling... the plywoods ended up (for a 29x26 machine) 29 x 25 -3/4 on one side and 23" on the other!!! that's a trapeze! we measured them there and they seemed fine... I discovered the mistakes when trying to put'em together... the cutting cost 25 cents per cut. (though the dude did it free for me) But beware guys! might be cheaper just to own one of these lil rotary hand saws (how'r they called?) and do it in one's garage
May 16, 2010. 7:35 PMnaglies says:
Great job on the instructable.   I am not handy and was able to complete this without difficulty.   I found a dresser being thrown out  2 days before I bought my washer and wouldn't you know the darn things fit perfectly!  I just threw in a 2x4 towards the front of the opening for it to rest on.  A little candle wax and a planer and the two drawers slide beautifully.   I made my peds  2 "  higher than yours and added a 2x4 in the back but otherwise followed your lead.  No issues with vibration at all.  They are level and  very stable / strong.
The big test was what my wife would say...and she likes them.  Thanks again.......Naglies
May 8, 2010. 7:22 AMchukkerlukker says:
Great job, raxel.  Did this for our new front loader washer, as well as for aging knees.  I added two things: 1) A piece of slotted angle-iron across the front edge, between the plywood & the 2x3 to give the opening some more rigidity, and 2) extended the top piece back about 4 inches, so that it would clear the baseboard in our laundry nook, and butt against the wall.  Then I added a 2x3, on the 2" edge, on top of that, well attached by screws from the bottom.  If I ever feel the need to attach it to the wall, all I have to do is sink some long screws thru the 3" face into the wall & studs.
Guys installing our new washer were very impressed!  They said, "No way would I pay $200+ for a drawer!
Apr 26, 2010. 11:40 AMmikemary says:
The manuals for these types of washers say they must be on a concrete floor. I know people who used a wooden platform and their washers had problems. It took about 2 to 2 1/2 years but the washer failed prematurely. It has to do with how fast it spins to get the water out of the clothes. Much, much faster than top load washers. Even a small amount of vibrations (that you can't see) will put stress on the internal parts.
Apr 25, 2010. 7:17 AMBiffTirkle says:
i am an appliance repair technician by trade. these homemade pedestals usually cause  problems.
the dryer will/should be fine. but the washer needs 700lbs of support under it to operate properly. ive seen joists damaged because of these machines.
a front load washer is an off balance wheel.
ive seen a few work. but not many. i hope these work for you. but to anyone else contemplating it. i hope this was helpfull.
Apr 22, 2010. 6:28 AMcararta says:
If worried about vibration, would it make sense to add a 2x4 border around the outside of the top?  Should be strong enough to keep appliances from taking a trip!
Aug 6, 2009. 10:35 AMPS118 says:
I second Igarcia's thing. I'm worried about the vibration. My frontload washer is already kinda shakey. Though I imagine if you bolted both stands together it would help for starters.
Apr 20, 2010. 7:49 AMHaymaker007 says:
If your front load is shaky or vibrating then it is not level side to side or front to back. Having said this if you do not level it the inside tumbler will vibrate and rub against the side housing and at some point will cause the full machine to fail. Of course not counting those loads where the jeans are on one side and the light and frilly on the other side.
Good idea to have some form of levelling whether adjustable or shims although both washer and dryer also have a certain amount of internal levelling capability
BTW raxel I think this is a great project
Apr 16, 2010. 3:11 PMflippedcracker says:
i'm just wondering, once you finished the pedestals, how did you get the washer and dryer on top of them?
Mar 3, 2010. 7:44 AMsuzpac says:
Thank you so much for this idea! We went a little taller and wider (almost 19" high now) and it is great!. We wanted that warm and fuzzy feeling about it holding the washer, so we also added another brace in the middle. It cost us about $50. at Lowes. That was for the material. They did all the cuts for free. Thanks again!
Jan 23, 2010. 1:05 PMEd Joyner says:
Nice design.  This morning I went to Home Depot, got them to cut the materials while there, built it and put primer coat on by 2:45 pm all in the same day.  It is sturdy.  Thank you.
Jan 24, 2010. 5:16 AMEd Joyner says:
Now I need to learn how to post pictures on the internet!
Jan 6, 2010. 7:02 AMcbriody says:
So just wondering, now that you've been using the pedestals for a while, have you had any issues?  Is it any noisier?  Have you noticed the pedestals weakening at all?  There are plenty of sites that tell you that making your own pedestals isn't recommended because they could break and cause significant damage to your washer/dryer, yet there are plenty of sites out there showing people who have done this.  None of these sites ever have follow-ups though after people have used their designs for a few months.
Jan 6, 2010. 7:09 AMcbriody says:
One other thing I noticed about this design that's different from all the others that I've seen is that your pedestals are open on the bottom and front sides.  So again, just wondering how that affects the stability (if you've noticed at all).
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:raxel(Artsybelle)
Just having some fun with junx and recycling stuff! If you have anything to ask on just about anything, please don't hesitate.
