3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Washing Machine and Dryer pedestal / Stand: A DIY Happiness!
Step 2Take Measurements
Take Measurements
1. Make measurements around the base of your washer and dryer. My measurement was 27" around, a perfect square. Mark this measurement ion the plywood. This will serve as the top panel where the washer and dryer would sit. 27" x 27". (have Home Depot cut it)
2. Make measurements for the height of your pedestal. In this instructible, the height for my pedestal was 15". Most pedestals are around this height range.
3. Mark your measurement for height on the plywood and also your length. This will serve as the side panels. In this case two 15" x 27". (again, have Home Depot cut it)
4. Measure and mark the 2" x 4"s. Two 25" for the length and four 13" for the height. The four 13" would serve as the leg support .
*note* 25" is the length because the plywood was about an inch thick. Depending on the thickness of your plywood, you just have to make the necessary adjustments. You don't want the side panels protruding on the side. We want to seamlessly connect the woods together.
To do this, just subtract the thickness of the 2 side panels from the main length of the base of your washer or dryer. That will be the length of your 2x4's. Hope that made sense.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:raxel(Artsybelle)
Just having some fun with junx and recycling stuff! If you have anything to ask on just about anything, please don't hesitate.
