3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Waste Veggie Oil Heater
One of the primary issues with driving a vehicle that runs on waste veggie oil is getting that oil hot. Both in the car and when filtering. Here is a simple/inexpensive way to heat up your oil using only two items - magnet wire (30 gauge) and aluminum tape.
Step 1Wire Calculations
Wire Calculations
I am using a 30 gauge red magnet wire obtained from Radio Shack. The resistance of this wire is roughly .26 ohm per foot. We need to do some simple math to figure out how much energy and wire we want to use.
My goal was a heater that was about 60W. Here is the way I calculated it.
20' of wire is has a resistance of 5.19 ohm
E=IR
12V = (I) 5.19ohm
12 / 5.19 = I = 2.31A
P=IE
12V * 2.31A = 27.7W
About 20' of wire gives me close to 30W of energy. I ended up using two 20' segments for a total of 60W of power.
21 comments
Dec 10, 2010. 11:52 PMjedwardbarker says:
Great idea; I just completed a 12v heated fuel pickup with this design. But that math is all wrong. 20' of 30 AWG wire has a resistance of 2.064 ohms, then:
E=I x R
12v = I x 2.064 ohms
i = 5.81 amps
I is current, not power. To find power:
P = E x I
P = 12v x 5.81
P = 69.7 watts
So, each of those coils is actually about 70 watts. That's 140 watt heater, not a 60 watt.
Dec 11, 2010. 10:16 AMjedwardbarker says:
So there's really that much variance in the resistance?
Jul 26, 2008. 2:37 PMdrinkmorecoffee says:
I like this idea, I think I'll use it to heat something a little bit larger, though. Like, say, a 55 gallon drum of WVO, to separate all the moisture and gunk from the good oil. I've been playing around with heating oil in carboys, and I can get the maximum amount of oil out of the cloudy stuff that doesn't like to react for biodiesel when I heat it to about 100 degrees F. Cheers! -DMC
Jul 26, 2008. 4:43 PMdrinkmorecoffee says:
Actually, that's exactly what we're doing right now. They don't get quite hot enough just sitting in the sun (we have lots of trees, so we only get so much sun in one spot during the day), so this is perfect. What kind of alluminum tape is that? Lowes has 3 or 4 different kinds, one roll is $6, another $8, and a higher grade tape for $16 a roll.
Jul 17, 2008. 1:33 PMMatt D655 says:
Can a gas car run on this stuff?
Mar 17, 2008. 3:13 PMGorillazMiko says:
Great Instructable, I might show this to my mom if we ever need to do something like this.
Mar 16, 2008. 3:02 PMthinkahead says:
Wrapping the magnet wire around an iron bar placed inside the waste veggie oil container and switching the current through it at a selected rate might produce inductive heating that is easier and more efficient to control.
Mar 17, 2008. 2:01 PMthinkahead says:
Experiment. Start with lowest frequency you can generate then measure temp. Build a frequency to temperature table and then make a chart. Next build a feedback loop using a thermister and controller to keep temperature at maximum or at least constant.
Mar 16, 2008. 2:20 PMLinuxH4x0r says:
Couldn't you just use a radiator filled with coolant from the engine? Besides that, great instructable. BTW: What do you use this in? I'm thinking of buying a vw golf tdi, or maybe a jetta. Any suggestions?
Mar 16, 2008. 3:53 PMLinuxH4x0r says:
Do you know about b20? Is it ok to run without converting it? How about b20 in summer, and 100% diesel in winter?
Mar 16, 2008. 5:43 PMLinuxH4x0r says:
I'm in santa fe, NM, But I will probably go to MN alot, so a heater would be good. Does b100 need modification? I don't want to mod it, but I also don't want to ruin it. What is the highest I can run? The place that sells b20 is in town (less than 10 mi away)
Mar 16, 2008. 6:26 PMLinuxH4x0r says:
Thanks! I might just do that. What is the advantage to the high end ones? I was also considering a CNG conversion. What do you think about that?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:sklarm
Building a hotel from waste materials in southern New Mexico.
