I had been looking on-line for sustainable lighting alternatives and I found a lot of sites that had instructions for veggie oil lamps. However, almost all of them used the wire coil method for holding the wick in place and many people complained about it being too difficult to raise the wick when needed. So I came up with an easier wick holder. This project takes very little time to complete.
Items I used:
A glass jar
Used veggie oil (it can be fresh but that would be wasteful)
Cotton material for the wick
A metal bottle cap
Wire
A nail and hammer for making holes in the bottle cap
Needle nose pliers
A small bowl of salt water
Remove these ads by
Signing UpStep 1The Wick
I then soaked them in salt water (using regular table salt) for a minute and laid them outside to dry in the sun.
After they were dry, I stapled the fat end (at the bottom of the 2nd pic) and braided it tightly.
The reason you have to sand the galvanized wire is the zinc emits toxic fumes when heated, so it needs to be removed for safety's sake.
http://www.youtube.com/watch?v=_Kj07QpHo1c
But here comes the question: once you light your wick it will start consuming oil. this means that the level of oil will drop. then the oil with have a hard time climbing upstairs in the wick to get burned in the flame. There is nothing "sucking" it up. this in the end causes the wick to burn (not the oil in it)...
Can you think of some way to let the wick holder FLOAT in top of the oil to prevent this?
