Water Alarm Ball
454
5
Posted
Introduction: Water Alarm Ball
this is water alarm ball,
this is very usefull gadget,
and helping in save water.
Step 1: What You Need
you need
one bc547 transistor,
PCB,
3.7 v li ion battery,
piezo buzzer,
switch,
one plastic ball.
Step 2: Build Circuit
build circuit as circuit diagram with PCB&soldering iron
Step 3: Fitting All Component
fitting all component in ball,
first cut the ball with cutter,
and fix circuit in ball and out side two wire
and joint the ball.
for full voice some do hole in ball opposite site of two wire.
Step 4: Use
where do hole in ball fix rope with small hangar,
and hang over the water container,
when water rise up to ball two terminal and touch water,
the buzzer is activate.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    3 Comments
    Are you sure of your schematic diagram? Seem you are trying to bias the NPN transistor with a ground. Usually this type circuit uses the positive lead from the battery to bias the base when current flows through the water probes. Just wondering.
    it's working
    just one transistor use as switch
    Is the battery turned around?
