3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Block
Water Block
  • last photo ←
This is my homemade water block that I milled out of solid aluminum, I created it for cooling a TEC.
15 comments
Feb 25, 2012. 6:30 AMjunits15 says:
I like it; very simple. Nice to see some people doing this stuff with household tools finally :) *****
Dec 30, 2011. 9:21 AMsnowluck2345 says:
have you had any corrosion problems with it? Brass and aluminum usualy corrode.
Aug 6, 2011. 3:54 AMPhil B says:
I have no idea what this does other than cool water for something. I "googled" TEC and have no idea what that is, either.
Dec 26, 2011. 5:40 PMsnowluck2345 says:
well your just not the sharpest tool in the shed then.
Aug 6, 2011. 11:01 PMabadfart says:
it is a radiator system for your computer so instead of air passing over fins to cool it it pumps water
Aug 6, 2011. 9:23 AMDavidFerAndersson says:
A TEC would be a thermo electric coupling device... such as this http://en.wikipedia.org/wiki/Thermoelectric_effect
The block would be used to cool the hot side of the device.
Good job on the water block!
Aug 6, 2011. 10:19 AMPhil B says:
Thank you.
Sep 30, 2011. 2:42 AMGnutella says:
Neatly done.i just wish i had powertools.
Aug 7, 2011. 12:16 AMabadfart says:
very nice, if you were to put the barbs in on the side you could use it as a gpu cooler
Aug 6, 2011. 6:26 PMReffner says:
If this is going to be used around anything electrical I strongly suggest milling a groove around the perimeter for some type of rubber/watertight gasket.
Aug 6, 2011. 7:13 PMrimar2000 says:
Good work, but: what is the advantage of this over a copper or aluminum tube coil?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:mr. clean
