I was trying to find some cheap material to buil a new bass box to my car sound system, then it came to me: I find a water bottle near a trash container. Immediately I imagine that I could use it in my new project.
This instructable is the result of this project.
Excluding the price of the subwoofer (I already have it), all the project cost me US$15
Hope you enjoy it as much as I do. And please! Rate it! Thanks!
Remove these ads by
Signing UpStep 1List of Material
1 Subwoofer 12" (inches) diameter
1 Water bottle 12" diameter (maybe you'll need more if your subwoofer requires)
Acrilic blanket (enough to coat inner side of the bass box)
Perforated Hanger Iron
8 Small Corner brace
8 long bolts with nuts and washer
1 smal bolt with nut and washers to tighten the perforated hanger iron
1 female P10 mono connector
1 male P10 mono connector
two way cable
Silicone Glue to seal
Tools:
Scissors
screw driver
jigsaw
plyers
soldering iron
![national-zinc-corner-iron[1].jpg](http://img.instructables.com/files/deriv/FIL/OZZS/GEFGGRU8/FILOZZSGEFGGRU8.SQUARE.jpg)
![perforated-iron-hanger[1].jpg](http://img.instructables.com/files/deriv/F0E/IEGO/GEFGD5GR/F0EIEGOGEFGD5GR.SQUARE.jpg)
You'd have a much louder woofer and way less distortion if you used plywood of mdf. Plywood is actually better than mdf, since it's stiffer, and will distort less.
(im going to use mdf too)
http://www.panoxadrez.com.br/lojas/00005983/prod/mantab.JPG
also know as Perlon(tm).
