3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Bottle Bazooka
  • last photo ←
Have you ever wanted to fire a water bottle from a shoulder-mounted launcher? I know I have. This Instructable takes the basic "water bottle rocket" science lesson and expands on it, combining the ability to aim with a convenient trigger mechanism. It can be built in a few hours using parts from a hardware store. But before I continue, here is the requisite disclaimer:
PLEASE, do not aim the Bazooka at people, animals, your neighbour's prize-winning tomato plants, or other objects that may be damaged. Only launch outside. Don't do anything stupid, like lighting the bottle on fire before launching it. Use only water as a propellant. Do not over-pressurize the bottle. Use under adult supervision. Keep small children away (regardless of my video!) Use the thinking part of your brain.
MOST IMPORTANTLY, do try to retrieve every bottle you launch. Let's not litter, okay? I'd also suggest using "reclaimed" water as propellant, such as rainwater, snow melt, or the like.
Step 1Materials and Tools
Materials and Tools
Here is a list of materials you will need to build the Water Bottle Bazooka
3-4 feet of 3" diameter ABS pipe
One 3" to 1.5" ABS reduction adapter
One 1.5" to 0.5" ABS threaded pipe adapter
One 1" inside diameter metal washer
About 6" of scrap 2x4
About 6" of 3/4" diameter plastic pipe (any kind)
One #4 rubber stopper, solid core (cork won't work, it has too many holes!)
A bicycle brake lever
Bicycle brake cable housing (cut to fit)
Bicycle brake cable (cut to fit)
A brake cable clamp or similar
Any sort of glue that will adhere plastic to plastic, and wood to plastic
Water bottles - 500mL size, or anything that will fit in the launch tube
Bicycle pump
A long Presta valve - a used bike tire tube is a good place to get one!
And here are some tools that you'll probably need:
Something to cut metal - a Dremel or metal-cutting bandsaw would work best
Something to cut plastic - a handsaw or miter saw or something similar
Something to cut wood - really, any sort of saw would work.
A drill press (or a hand drill, in a pinch)
A sharp utility knife or X-acto knife
Assorted measuring and marking implements
198 comments
1-40 of 198next »
Apr 17, 2012. 4:28 PMHollyMann says:
My son would love this!
Jan 11, 2012. 1:06 PMsplintercell13 says:
(removed by author or community request)
Jan 18, 2009. 9:23 AMdisturbedreaper says:
i wonder if i could put watersoluable paint in it and use if for paint ball instead
Dec 22, 2011. 7:22 AMGuitarGuyJames says:
Well, if you made a cardboard shell for paintballs with flaps cut into the front, it should work. The flaps will open when the shell is shot, and the paintballs will keep going. As long as there is a tight enough seal and you understand me correctly, it should work.
Jul 10, 2011. 10:00 PMtha_jaker says:
Maby put paintballs on top if the water bottle so that when you launch the water bottle the paintballs come out as well.
Jan 18, 2009. 1:05 PMdisturbedreaper says:
yea i agree but ive ben brain storming and mabey with a sheild and shoot it over the enemys heads so it puors out on them? ill work on the idea after midterms
Jan 19, 2009. 6:53 AMdisturbedreaper says:
yea like i said though i need time for midterms (yea) : (
Jan 19, 2009. 11:18 AMcodongolev says:
fill them with paint like you said, but put the bottle backwards and stop it from moving to propel the paint forward.
or put watery paint in a squirt gun, but that's not nearly as fun.
Jan 19, 2009. 2:45 PMdisturbedreaper says:
he said that look at the small text
May 18, 2011. 6:55 PMilpug says:
you could put a water baloon full of paint on the front of the rocket
Nov 11, 2011. 4:54 PMNicholai says:
aquafina bottles suck and die when used as ammo, use Smart Water, they last forever and get pretty good distance. an aquafina bottle expanded on the second launch attempt and got stuck in the tube, epic fail.
May 25, 2010. 4:18 PMm1keo says:
I use this for paintball. Just fill the bottle with water and paint from my old saggy balls.
Jul 5, 2011. 5:39 AMm1keo says:
THE PAST IS THE PAST LET IT GO!
Jul 3, 2011. 2:39 PMNE patsrock says:
wow kool did it work well?
Jul 4, 2011. 4:29 AMm1keo says:
After lots of modifications yes.
Jul 4, 2011. 7:11 PMNE patsrock says:
ha funny:)
Jul 1, 2011. 3:32 PMacdc1226 says:
well then..........................
May 18, 2011. 6:42 PMilpug says:
that doesn't sound wrong at all
May 30, 2011. 7:16 PMm1keo says:
Oh god, I didn't think before writing that, by "my old saggy balls" I meant bad paint balls.
May 18, 2011. 11:42 PMThe Locksmith says:
No, not in the least.
May 31, 2011. 1:15 PMilpug says:
its all good. i understood your meaning, but i has a dirty mind so i had to point that out XD
Jul 1, 2011. 3:33 PMacdc1226 says:
same here lolz
Jul 3, 2011. 2:38 PMNE patsrock says:
ok this is about the best thing i found under rockets idk how u made it or even thought of it but this thing is krazy awesome but the waterbottle dousnt go really far
Jul 4, 2011. 7:13 PMNE patsrock says:
ya a nose cone and some fins would be good
May 19, 2011. 9:02 PMShadow13! says:
Soda bottle are built to resist more pressure because they have to hold in the carbonation if you use a soda bottle then you could pump it to a hire pressure with out fear of the bottle bursting.
May 2, 2009. 6:20 PMGEEK1 says:
you should also make fins for the bottle for a more stable flight
May 18, 2011. 6:45 PMilpug says:
definitely. and tape on some pennies to balance the flight.
Jun 17, 2009. 8:38 AMFridge Gnome says:
would it be safe/possible to use green gas instead of a bike pump
Jul 2, 2009. 5:16 PMCountry dude says:
I have a Jac Pac CO2 regulator it will run off everything from 3 oz to 20 oz and it works great for my paintball rocket launcher
1-40 of 198next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
