3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Bottle Bazooka
Step 8Assemble the Release Assembly
  • last photo ←
Grab the reduction coupler and the L-shaped piece of wood. The L-shape will be glued onto the reduction coupler, so that the hole for the cable is centered above the slot cut for the washer. Start by roughening the surface of the coupler with sandpaper, where the wood will be glued. Apply hot glue (or anything that will adhere wood to plastic) to the wood, stick it in position, then run a bead of hot glue around the edge as well.
Slide the reduction coupler onto the end of the 3" pipe and push it down as far as it will go. The L-shape should be on the top of the launch tube. It probably won't be necessary to glue it in place, since the fit will be pretty tight. But, you may go ahead and use glue if you like.
Insert the stopper in an empty bottle as far as it will go. Load it into the launch tube, then slide in the washer to lock the bottle in place. Now, take the threaded coupler and insert it into the narrow end of the reduction coupler. The threaded coupler should push right up against the stopper - remember, when you're filling the bottle with air the stopper will want to pop out. The threaded coupler is there to stop that from happening. Dry-fit the coupler and test the release lever a few times. Everything should be precisely positioned so that the bottle can be securely locked by sliding the washer in the slot. Glue the threaded coupler in place when you have found the optimum position.
1 comment
May 28, 2010. 10:55 AMNicholai says:
does the presta valve and cork stay in the bottle during flight or do they both stay in the launcher?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
