3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Bottle Bazooka
Step 9Run the Release Cable
Start by sizing the brake cable housing to reach between the brake lever and the release mechanism. Make sure there is enough curve in the cable to promote easy operation. Cut the housing with side cutters, and open up the ends with a knife if necessary.
Run a brake cable through the housing. The cable should be about six inches longer than the housing. Start at the brake lever, threading the knobby end of the cable into the catch on the lever. Slide the housing in place on the brake.
On the release assembly, thread the cable through the hole. Grab the cable clamp and slide it through the washer. Slide the cable through the hole in the cable clamp. You may add a small spring between the release arm and the washer if you like. Holding the washer in the "locked" position, pull the cable tight, and tighten the nut on the cable clamp. Test the release assembly by squeezing the brake lever - the washer should pull out of the slot just enough to release the bottle.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
