Water Bottle Capacitor
1,639
29
Posted
Introduction: Water Bottle Capacitor
This capacitor probably won't be the strongest, just saying.
So, here's what you need:
1x empty water bottle
Vinegar
Copper Wire
Tin foil
Step 1:
Start by filling the water bottle 70-80% full with the vinegar.
Step 2:
Next, poke a hole in the top. You may use a nail and a hammer.
Step 3:
Put the wire through the hole, so it goes well into the vinegar.
Step 4:
Bend the top of the wire, so it doesn't fall through.
Step 5:
Wrap a good amount of tin foil around the outside of the bottle, and tape it in place.
Step 6:
Connect one alligator clip the some of the exposed tin foil.
Step 7:
Connect the other one to the exposed wire
Step 8:
Connect the ends of the clips to so one goes to each of the leads of a 9v power supply. Take note of which clip goes to positive!
Step 9:
Leave it on for an hour.
Step 10:
Now it's ready! It should look like the pictures above. Good work :)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
2 Comments
Any rough estimate of the capacity in pF, mF or F? Probably better to just buy a bottle of vinegar for 89 cents and use that. Does glass work better than plastic?
no idea about it's capacity. Plastic bottles should work better, because the plastic is usually thinner than the glass. Buying a vinegar bottle could work better.
