Water Bottle Tripod!
 by iMac
In this instructable, I will show you how to make a cheap and sturdy tripod out of a water bottle and a few of very easy to find objects for your camera.
All you need is:
Water Bottle (With water in it)
Water Bottle Cap
A Knife
Nut and Bolt
And a camera
Step 1: Make The Cap
Take your cap, and cut a hole in it, large enough to fit the bolt, but small enough that its a tight fit.
Note: Make sure your bolt is the correct size to fit in your tripod slot on your camera
Once you have your hole, push the bolt through in, and screw on your nut, like the picture below.
Done!
J@50n says: Feb 5, 2010. 9:16 AM
 Great idea actually! you can now go to the zoo or anywhere and have a tripos without draggin the big honker a long.
dreath77 says: Jun 17, 2009. 8:43 PM
drinkable and functional
dreath77 says: Jun 17, 2009. 1:17 PM
i tried this before with normal bottle water, i open the bottle, squizze it so it gets the shape of me holding it, then seal it, even using that on the water tripod, it can be mobile.or atleast more able to be held.
yodog4444 says: Feb 7, 2009. 9:36 PM
great idea, i think i'll do this tomarrow, but it would be better if you cut 4 holes on the side of the bottle near the bottom, and cross/ secure 2 pencils through it for a better stand so it doesn't tip over as easily. but this would make it so you cant drink from it obviously.
jeff-o says: Jan 20, 2009. 11:14 AM
I'd suggest using sand instead of water, but other than that this is a cool idea!
polonium9 in reply to jeff-oJan 26, 2009. 6:39 AM
im sorry to say this but you cant drink sand
iMac (author) in reply to jeff-oJan 20, 2009. 2:45 PM
If you use sand, you cant drink out of it, the great thing about this is that its a multi tasker
l333333333t says: Jan 25, 2009. 2:11 AM
Man this has potential for sure
Try a weight in the bottom
11111111111111oneoneoneoneonoeneone
http://forum.bodybuilding.com/forumdisplay.php?f=19
LunaticModRep says: Jan 25, 2009. 2:00 AM
Wow, what a handy and cool thing! As a miscer I feel obligated to JEEEEEEEEEP BRAAAAAAAAHH
elliot33 says: Jan 25, 2009. 1:55 AM
MISC brah, this is awesome
dkfa says: Jan 20, 2009. 4:31 PM
What would happen if the bottle was to spill over your flip mino? I have a flip mino and im not risking it near water....
iMac (author) in reply to dkfaJan 21, 2009. 1:05 PM
If it fell, the water wouldnt spill, becuase the the bolt has a tight fit in the hole. If you are really worried about it, you can just put some glue around the hole.
DJ Radio says: Jan 20, 2009. 1:33 PM
looks cool, 5*
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
