3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Cooling
Step 2Remove the heat sink
Once the motherboard is loose, unclip and remove the heat sink. This will have a fan and is in the center of the chip. Make sure not to rip the chip straight off the motherboard. Use a gentle twist and slide motion because the thermal paste already on the chip makes a tight bond. Then clean the top of the exposed chip with an alcohol wipe and apply thermal paste (a conductive metal- or silicone-based grease that should come with the kit).
Pictured here: The heat sink after it is removed, cleaned and the water block is attached (see step 3).
2 comments
Jan 31, 2009. 12:27 AMMuscelz says:
NEVER AND I REPEAT NEVER USE PLASTIC FACED WATER BLOCKS! THEY WILL CRACK! USE FULL COPPER OR ALUMINUM WATER BLOCK! I HAVE SEEN TO MANY ACCIDENTS AND CRACKED WATERBLOCKS
Mar 11, 2007. 8:07 PMLJames says:
Just looking at the close-up of the hose connections; I wouldn't trust those hose clamps not to leak; I would rather use screw-type clamps. As someone else commented, it would be best to test it for leaks outside the PC. I would also like to see some reports on the reliability of this cooler being leak-proof. One "little" leak is one too many in the middle of all that expensive electronics!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
118
Author:Popular Mechanics
The official instructable for Popular Mechanics magazine, reporting on the DIY world since 1902.
