Water Filter - the DIY (Straw-Style) Water Filter! - Survival/SHTF Water Filter - Easy DIY
Published
Introduction: Water Filter - the DIY (Straw-Style) Water Filter! - Survival/SHTF Water Filter - Easy DIY
About: hi there. on this instructable channel i'll be covering all types of DIY solar power projects (as well as off-grid/survival/green living projects) that are easy to make out of readily available products and ...
in this instructable i'll show you how i made a "straw style" water filter
Step 1: Watch the Instructional Video...
Step 2: Read the Description...
Homemade "Straw Style" Water Filter!. Easy DIY. This Straw Style Water Filter is small, lightweight and powerful. good to have when hiking/camping and ideal for in a SHTF/Emergency situation. is 99.9% effective at removing many common disease/cancer causing water contaminants. also is excellent for purifying rain (or tap) water. full step-by-step instructions. items needed: poultry baster, coffee filters, cotton balls (optional) and activated carbon. *all items found at dollar store - except the activated carbon ($6.00 at walmart). also sold at most aquarium supply stores. filter should last for years with regular maintenance. the activated carbon is rated to last 5 1/2 months (24 weeks) if used continuously. change cotton/coffee filters as needed.
Step 3: First: Gather the Items...
1.) one turkey/poultry baster (to make the "straw"). cost $1.00
2.) activated carbon (from walmart, most aquarium supply stores or amazon). $6.00 for large jug of it
3.) paper coffee filters ($1.00)
4.) cotton balls ($1.00)
5.) rubber band, string or twist tie (free)
Step 4: First, Remove End of Baster and Add Cotton Ball
push it down into the tip (end) of baster (see pics above)
Step 5: Rinse the Activated Carbon...
new activated carbon has a very fine residue on it. for it to work properly you need to rinse it first. be patient because that can take a few minutes (see pics above). after rinsing, clean the sink!
Step 6: Add It...
Step 7: Add Cotton Balls to the Other End (the Top)...
Step 8: And Finally, Cap It Off (with Coffee Filter Paper)
cut down coffee filter and make a cap for the end. attach it with a rubber band, string or a twist tie
Step 9: Give It a Try...
effectively filters tap-water, rain-water, river-water. This type of filter works best to purify tap water, rain water and river-water. the filter eliminates any bad taste/odor and restores clarity to water. it also removes silt, debris, sediment along with over 200 chemical contaminants (including herbicides/pesticides, pharmaceuticals and on and on). note that if you are filtering lake/pond water (or any other stagnant body of water that may contain pathogens) you should pour water thru filter and into a collection container and boil it before drinking. boiling can be done before or after you pour water thru the filter. note: nothing grows in fast moving river water so that does not need to be boiled.
Step 10: Here's How to Pour Water Thru It...
cut the top off of the bulb part of the baster and connect it. then just pour water in and hold over a container (to collect the filtered water).
Step 11: Have Fun Making and Using It!
here's a few extra pics
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    Very nice, but a "Life Straw" uses silver impregnated charcoal. Silver kills bacteria and viruses. If your straw does not incorporate silver...then my young padawan.....you will die..
