Are the water supply lines under your sink leaking? Did a cracked or broken plastic fitting cause your bathroom to flood? Should you call a plumber?......not if you like saving money!
You can fix it yourself! Here's how...
Remove these ads by
Signing UpStep 1Identifying Your Water Line
This instructable addresses how to repair or replace a PEX water supply line.
How do I know whether or not my water supply line is PEX?
There are three easy ways to identify PEX tubing:
Note: If the first two identifying features are not true of your water supply line, please do not attempt the third. Bending a PVC or Copper supply line will not end well!
1) PEX tubing comes in two different colors, solid white and solid red. (White denotes a cold water line, while red denotes a hot water line).
2) PEX tubing has printed lettering that contains the words "PEX" (see figure below).
3) PEX tubing is rather flexible and easy to bend. (Be careful not to break your supply line by testing its flexibility).
If you have safely identified your water supply line as PEX tubing, then it's your lucky day! Continue reading to learn how you can easily repair your water lines.
Add Comment
