3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Powered Calculator (Original)
This Instructable will show you how to make a very simple water powered calculator.
I built this because there was a time that we forget to buy a supply of AAA, AA, C, D and LR44
battery so I built this. It solve my problems so it might do the same for you too. Check out for more projects by: angelo10.
This is the original version by: angelo10
Please give the credits to me not for your selves. I saw people getting my pictures and telling  others that they made it. Please don't get all the credits!
Proud to be Filipino (pinoy) like Manny Pacquiao.
Step 1Meterials You Will Need
You will need:
- A Calculator
- Carbon Rod/ Copper Rod
- A 1x1 Inch Aluminum Foil
- A Small Cylindrical Container
- Two 3 Inch Wire
- Multi Purpose Pliers
- Glue Gun
119 comments
1-40 of 119next »
Jul 10, 2010. 4:33 PMDipankar says:
How long does the battery work? Good Idea. Keep it up.
Jul 11, 2010. 9:42 PMmathman47 says:
I think we have a good kid here. Now if he'll take after you.
Jul 11, 2010. 11:30 PMartworker says:
Innovative. Nicely done! It's sad that teachers don't encourage these projects in school! Every student should know these tricks. 5*
Jul 12, 2010. 4:49 PMDipankar says:
Yeh! He's a bright kid. Hope he does well in life.
Jul 12, 2010. 10:48 PMchaitanyak says:
most innovative - yet simple thing i found today! Good job!
Apr 30, 2011. 11:50 AMjmcdermott says:
silly matrix, inside duh
May 11, 2011. 3:19 PMaschmois says:
Great tutorial, my first try I had water leaking from everywhere and only a mere .3-.5 volts. Vinegar is NOT the best solution. I have tried and what seems to work best is Lemon Juice and Salt. (water and salt is still better than vinegar). The picture has two batteries in series which add up to a good 1.5 volts. However, for some reason I cannot get a light to turn on. My guess is that voltage reading stabilizes with a circuit, but the bulb cannot stabilize. Might also be the amperage not being high enough.
Dec 6, 2011. 5:10 AMshalo says:
aside from batteries where can you find those cooper rods? pls help im so desperate :( and im from the philippines as well so if you a pls tell me:)
Dec 24, 2011. 9:04 PMPranjal Joshi says:
this is marvelous project...!!
bt u cn do better with carbon n zinc rod using general acids.. :) wel done
Dec 29, 2011. 9:05 AMdagob says:
What an interesting instructable! Thanks for sharing!
I think you should explaing why it works (scientifically)
Feb 6, 2012. 6:16 PMaustinbro217 says:
Nice job man! I am just starting to explore electronics at 15 years old, and you are an inspiration for me to keep with it!
May 30, 2012. 5:50 PMTheBookworm says:
Sweet project, I wonder if it will work with some lemons...
Jan 8, 2011. 9:01 PMInducktion says:
ooo, try gatorade! (lotsa electrolytes in thurr!) :D
Mar 5, 2011. 10:02 PMyukthi says:
yeah u r correct !!!
Mar 4, 2012. 2:40 PMpblanscet says:
lol! scientificaly, would this really work?
Mar 4, 2012. 2:35 PMpblanscet says:
hey, im Filipino too!
Mar 4, 2012. 1:46 AMizdravkov says:
This is a Triboelectric! See this site for more information about Triboelectric series: http://www.siliconfareast.com/tribo_series.htm
Feb 12, 2012. 1:05 AMCeejay10 says:
HELLO, I'm from Philippines And I'm Interested to Buy a Calculator. Where can i order or s/t. ? Please.
Mar 9, 2012. 7:18 AMCeejay10 says:
Or Anything na pwede tayong makapagusap ng mabuti. hindi po kasi ako masaydong marunong dito.
Mar 9, 2012. 7:13 AMCeejay10 says:
Do you have Fb Account? Opo, Marunong ako. hahaha
Feb 12, 2012. 12:54 AMCeejay10 says:
May 27, 2011. 2:59 AMbloodgarm1 says:
i tried doing this but mine is not working... :( i have one doubt.. is it absolutely necessary that aluminium and carbon shouldnt come in contact?? in my model they are touching.. i just tried it 5 min back..
Dec 28, 2011. 8:24 PMMr Sinster says:
Do you get a lot of buyers of of this?
Dec 6, 2011. 5:09 AMshalo says:
Nov 16, 2011. 11:01 AMJavin007 says:
Things I have learned since reading this instructable:
1.) Energizer alkaline batteries do not have carbon rods.  The batteries are filled with an inside "sludge" of zinc powder and potassium hydroxide, inside of a paper tube with a black carbon and manganese dioxide "sludge" on the outside.
2.) Said black carbon sludge will stain a white porcelain sink.
3.) Fiance does not find any of this as fascinating as I do.
Mar 30, 2011. 3:00 PMBruno153 says:
My water battery only generated about 0.5 volt.... the calculator will need about 1.5 volt.... I added salt and then was the same....
Jun 9, 2011. 7:57 AMbatman96 says:
If you are putting the "water battery" in place of the solar cell, it will be enough those tiny solar cells only put out .5 volts in bright sun. If you are using a calculator that has a battery also, hook it up to the solar cell connections, because the battery connectors run through a resistor. If you put the battery in parallel with the solar cell you can leave it in and then it will use the battery when there is no sun, and the solar cell when there is light, and use both when it is dim. Just make sure you don't hook it up in series.
Nov 4, 2011. 10:53 AMeye881 says:
im doing this for my science fare in salem arkansas my teachers said i need 5 links that i got this info off of i put down lifehacker.com and instructables.com but i cant think of any other links.
1-40 of 119next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
132
Author:ASCAS(ASCAS.com)
My name is "Angelo S. Casimiro", I am now 13 years old. I got interested in electronics and mechanics when i was 4 year old. And started soldering circuits (kits) at 7 years old. And improved solder...
more »
