Water Powered Flashlight and Mobile Charger
2,970
22
22
Posted
Introduction: Water Powered Flashlight and Mobile Charger
Can we generate electricity from water?
Think!
In this Instructable I will show you how to generate electricity from Water.
This instructable was inspired from
https://www.instructables.com/id/Water-Powered-Fla...
Here, water is used as a source of energy. Follow the steps to make it more clear.
Step 1: Gather Materials
1. Bowl
2. A Coin
3. Water
4. Aluminium Foil
5. Salt
6. Toroid
7. 1k Resiistor
8. LED
9. BC548 Transistor
6. Wires
7. Duct Tape or any other
8. DC-DC Boost Converter
9. Multimeter
Step 2: Working of Cell
Here demonstrated is the cell for generating electricity from water. Aluminium is Cathode and Copper is Anode. By arranging the setup, you can get electricity. Now let's go for it!
Step 3: Chosing Anode and Cathode
Here we Use a Coin as anode. Because coin contains of about 92% copper. And Aluminium is connected to wire as shown in figure.
Use tape to adhere wire on the coin
Step 4: Arranging It Up
Drop Coin and Wire with Aluminium foil in water and connect it to multimeter. You will see that this cell will generate upto0.4v.
Note: They should not touch each other.
But this type of arrangement will not generate more than 0.45. So lets make it more practical!
Step 5: How to Make the Cell
Here also we take the coin as anode. Firstly take coin. But here we will not take directly water. Use wet tissue wipes as shown in figure and keep it on the coin.
Step 6: Hey Jude, Let's Make It Sour!
The the wet tissue and apply salt on it. As this galvanic cell loves salt.
Step 7: Completing Cell
Lets complete the cell by putting aluminium foil on the wet tissue and it will generate upto0.7v.
By this cell we can do anything. We can make a joule thief and light an led. So let's make it!
Step 8: Making a Joule Thief
Firstly to make a joule thief you should be ready with your toroid.
Take a ferrite bead and wind two wires. Join the ends of two different wires and your toroid should match the figure.
More the turns more would be the efficiency!
Now Follow the circuit Diagram and arrange the components as shown in it.
Step 9: We Made a Joule Thief!
Here this joule thief can survive upon 0.135v! But our cell produces upto0.7v So we can light an LED.
Step 10: Charging a Mobile
You can also charge up Your Mobile with this cell usiing A DC-DC Boost Converter which converts from upto0.5v to 5v.
So, That's all with this Instructable. Hope you like it!
Thanks!
  • See this-Patel Darshil
    Patel Darshil made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
13 Comments
Nice. But that is like saying a led-acid battery is water powered.
I don't remember physics we made at uni but these Volta batteries produce a very tiny energy. You can search on wikies and you'll find it produces almost nothing. The Joule thief increases the voltage but decreases the current, and this is not proportionnal, in fact, Joule thieves are high energy eaters. I'm pretty sure it'll take weeks to reload your phone, if it's reloaded. I even think any phone needs more energy in idle mode than the one you can collect here !
How much current can this supply at 5V?
The current during charging is enough to charge. My Nokia mobile was charged. And if it doesnt charge your mobile then take the output of joule thief and connect Dc-Dc boost converter to it!
Good Luck!
How long did it take it to fully charge?
It takes much to the phones nowadays because some phone have 5A charger. The viltage also drains from cell with the time.
So this doesn't really charge a phone (correct translation?)
Could you give some data on the charging, including the current?
Good Luck!
