Water-Powered Octocopter
10,178
66
8
Posted in Technology3D-Printing
Introduction: Water-Powered Octocopter
The power of water is sometimes understated, especially as a means of propulsion. This project uses the water and pressure from an ordinary garden hose to propel a 3D printed octo-copter into the skies.
This project only takes a couple hours, as all you need to do is print the file, screw it onto a hose, and turn on the tap. No other parts required.
Step 1: Print!
There are two options here. If you have access to a 3D printer, use the attached STL file to print out an octocopter. Use supports and solid infill to avoid leaks; less than 0.26mm layer height is recommended.
The second option is to use an external 3d printing service, specifically Shapeways. The model is at my Shapeways shop here, and is very inexpensive.
Step 2: De-support (for Home Printer-ers)
If you printed the octocopter at home, you'll need to remove the support structure. In Cura, my proffered software, there's a setting to only add support that touches the buildplate. Otherwise, there'll be support inside the tubes. This will probably not work, and you'll need some awesome Dremel skills to drill out all the support.
If you ordered it from Shapeways, you don't have to do this. Hooray!
Step 3: Fly!
Screw the octocopter into the end of a regular garden hose. Then, turn on the hose to full volume. Hold onto the hose a couple feet away, and use the inflexibility of the hose to guide the octocopter and keep it from falling over. Some hoses will work better than others-- look for the most flexible one in your house/garden.
Step 4: Modify!
The design files for the octocopter are available on Tinkercad, an easy-to-use web CAD program, here. Try to get better performance! What'll make it more stable, or fly higher? What happens when you vary the angles or number of thrusters?
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Yeah-- just don't wear anything that can't get wet!
    Yeah, you might want to leave your camera and phone inside the house....do'h!
    I can see something like this being built without a printer with something like PVC or some such...
    That is doubtful as PVC will be much heavier and likely not available in the small diameters required for the jets. I can see PVC easily being three times the weight of a printed version, rendering it unusable.
    Cool idea, just add arduino and some more parts for controlling water jets and you got your self a nice hovercraft :)
    Clever. This is a novel use of 3D printing...!
    Cool project! I've never seen something like this before!
