Introduction: Water Proof Switch
Picture of Water Proof Switch
Here is an easy instructible for making your electrical switch water proof and submersible.  I built a small battery operated watercraft and needed a switch that was submersible.  No one  makes a truly water proof or submersible switch.  I had to figure something out.....  Lets check it out......
Parts:  High temp hot glue, switch, and heat shrink.
(switch and heat shrink size will vary according to your needs)
Tools:  Scissors, lighter, and something to be able to press object flat.  (coke bottle top)
Step 1: Parts
Picture of Parts
Hot Glue stick
Switch
3/4 inch Heat Shrink (about 3 inches long)
Step 2: 1st Step
Picture of 1st Step
Shrink about 1/2 - 3/4 inch of one end and press flat till cool.  This is your first seal.  I put hot glue on the edge to help seal it.
Step 3: 2nd Step
Picture of 2nd Step
Make the necessary electrical connections and insert the switch.
Step 4: 3rd Step
Picture of 3rd Step
Inject High Temp hot glue.  The temperature of the hot glue will begin the shrinking process of the heat shrink, and seal the switch, wires and drip out of the end.
BE CAREFUL!!!!  THIS IS HOT!!!
It will ooze out.
Your are now ready to operate it in wet conditions.
About This Instructable
3,034views
6favorites
License:
Bio: I like to tinker and build things that seem fun to do.
More by palombo5050:Make It Glow.... Safely!Mighty Mini PizzaSoda Stream Nuggets
Add instructable to:
