Water Pump Clock
4,648
12
6
Posted
Introduction: Water Pump Clock
This instructable will show you how to turn an old automotive water pump into a clock. Every car nut needs a clock so why not have one made from car parts. This my first in a line of instructables im calling "car part furniture". Ill make and submit more as I obtain parts.
Step 1: Materials
First things first, you need to get your materials.
you need:
Water pump (mine came off my truck when i replaced it).
cd case
2 led lights
clear hose (not pictured)
Clock kit with numbers
hot glue
piece of wood to screw pump to
12v battery (not pictured)
Step 2: LED Lights
Start by hot gluing the led lights in two holes where the radiator hose and thermostat go. Then run the wires out the back where the pump used to bolt to the block. The clear hose goes on the pipe and the leds light up the hose but I dont have the money for a hose right now.
Step 3: Attach Clock Gear
Next we need to attach the clocks gear housing to the pump. We do this with 2 bolts and washers. Make sure the bolts are the same size as the original thermostat bolts.
Step 4: Clock Face
Next take the CD case and break the front cover off and cut the hinge off and paint it whatever color you want. Once the paint is dry you can attach it to the gear housing and attach the numbers.
Step 5: Mounting the Pump
Now the pump clock is done and you need to attach it to a piece of wood with 3" or longer screws. Then find a STUD and mount at least 2 of the screws into a stud. IF YOU DO NOT DO THIS IT WILL RIP OUT THE WALL, My pump weighs at least 15lbs. Now attach the battery to the wires and
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    6 Comments
    That looks like a Chevy water pump...possibly off a 99-06 silverado? Maybe not.. Cool idea though!
    Cool, all though at first I thought you were actually using the pump to shoot water at come sort of paddle/gear assembly to actually rotate the clock hands. What was i thinking :)
    HAHA I thought the exact same thing! That would have been better
    pretty tricky I'd think, still a fun instructable though, good job sco_oter
    this is so absurd and i love it. great job.
    Thanks! Too bad I cant make make the pulley spin :(
