3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Recycler (Grey Water)
The area that I live in has been in a drought for a year or more. As such we now have water restrictions on washing the car, watering the garden etc. Initially I set up a drainage hose from the washing machine outlet to containers outside to enable me to collect the waste water so I could water the garden. This process worked fine except for the back breaking work of emptying the waste water (grey water) onto various places in the garden.
The next stage was to develop an automatic system that would distribute the grey water into the garden and have the following features.
1) Filter the water before sending it to the garden.
2) Automatic pump to allow water to be delivered to the high end of the garden.
3) Timer to prevent water stagnating in the tank.
The system uses a wheeled trash bin which is made out of 5mm thick plastic (nice and sturdy). Grey water comes into the top of the bin into a filter. When the bin fills to around 3/4 full, a water level switch triggers the pump controller to turn on the pump sitting at the bottom of the bin. The pump continues to operate until the lower water level switch is triggered.
The pump controller also has some logic built into the program to detect if water is in the bin but not high enough to operate the high water level switch. If this situation occurs, at 10 hour timer is started. If the water stays in the bin for 10 hours the pump will start and empty the bin. This stops the water from stagnating. I also have another timer that detects the run time of the pump. If the pump runs for longer than an hour (without any of the level switches being triggered) then the fault LED will be lit and all pumping will stop. This would indicate that the output pipe is blocked.
Step 1The schematic of the pump controller.
The pump controller is built around a PICAXE 8m PIC. The reason I chose this particular PIC is that it is programmed in BASIC and is cheap ($4 AUD) and I can't program in C to save myself.
There are 3 float sensor switches used in the project. Two of these float sensor switches detect high and low water levels of the tank. The third sensor detects when the water filter needs a clean.
The controller also drives 3 LED's that are mounted on a remote indicator panel in the laundry that indicates pump running, filter clean required & fault condition.
The transformer I used in the project has a 24VAC tap that I was going to use to power some water solenoids. Any voltage from 12VAC to 18VAC can power the circuit. The voltage regulator doesn't get hot as the PIC only draws a few milliamps. I also use a resistor to reduce the unregulated voltage to the pump relay which may need to be altered depending on the relay voltage.
water.sch218 KB
77 comments
1-40 of 77next »
Oct 13, 2011. 7:51 PMhhamilton2 says:
Since you have an interest in sustainability, you might like this as well.
http://www.growingpower.org/aquaponics.htm
Nov 25, 2010. 3:23 PMGurunadha Reddy says:
How does this stuff work.
Nov 23, 2010. 4:38 PMGurunadha Reddy says:
Does this project have a purification or afitration device.
Jul 4, 2010. 4:46 PMharry88 says:
thanks
Jul 3, 2010. 9:16 AMharry88 says:
does it have to run on ac i was thinking running it on solar pannels
Apr 13, 2010. 1:52 PMnotsogoldenoldie says:
Hi,
for those interested in grey-water systems, check out Art Ludwig's 'laundry to landscape' system. It's similar to slemke's but uses the washing machine pump to directly deliver the water to the mulch-beds, bypassing the need for a sump/bilge pump. I believe Art also uses a fairly large bore pipe to avoid lint blockages.
Here's the link... http://www.oasisdesign.net/greywater/laundry/index.php
Oct 16, 2009. 8:56 AMgardenResQ says:
Grey is now the new green. Grey water, if utilised immediately in exits your bathroom, is considered safe. However we need to be responsible with our grey water and how we use it. Go easy on chemicals in the bathroom when cleaning the bath and shower. Divert the grey water to the sewer if you have a family member with a "funny tummy" and never use a fine mist sprayer to irrigate with. Choose a low pressure pump with a sprayer that results in large water droplets. This consideration will prevent your grey water entering your neighbors garden as well as public walkways and storm water drains. As far as expense is concerned a good grey water product, one that does not store water but simply filters and diverts, should cost no more than $400.
Jun 29, 2008. 1:12 PMDerin says:
could you use grey water from the balcony? that would be rare but would still be good
Dec 18, 2008. 1:36 PMMaster Yoda says:
is your picture a penguin from miniclip.com and the game club penguin?
Dec 18, 2008. 11:53 PMDerin says:
yes
Jul 5, 2009. 3:20 AMDerin says:
it has its own official site though
Jun 25, 2009. 10:44 AMdove cottage says:
This is a beautiful setup. Mine works off two trash cans, a hose and gravity. I simply haul my hose to the plants and set the timer on my watch. Our well went dry a year after we bought our home, so we haul in our own water. With a family of 7 we generate a lot of laundry & now we have a nice green landscape with a little bit of work. I do not recommend Borax . I have tested it two times, it will kill the plants. I use bleach occasionally ,so I don't worry about it. If it was regular I wouldn't dump it on your plants though.
Oct 22, 2008. 8:27 PMboarder2k7 says:
It seems like putting soapy water into the garden is going to have a detrimental impact on plant growth.
Jun 24, 2009. 1:04 AMausisit says:
no in fact it will help as when you buy wetta soil and other wetting agents they contain similar materials and the soapy water is good to get rid of aphids
Nov 25, 2008. 4:33 PMDru77 says:
Actually, the soap (phosphate or otherwise) is a great fertilizer for your lawn or garden. You have to make sure you switch to organic soaps, use NO bleach or powdered detergents (which contain heavy salts) in order to use this system. But liquid detergent can be great plant food in a system like this. What you don't want to do is put grey water ON the plants, but water the ground by running the outflow into a shallow pit next to the plants, which is filled with bark, stones or other porous materials.
Nov 25, 2008. 5:32 PMboarder2k7 says:
Alright yeah that makes sense, because I was thinking of the ramifications of putting all laundry water on the plants, and it didn't seem like it would be good. I guess you could add some sort of a bypass valve to the system to go into the regular sewer/septic system when you needed to use bleach or something in the load.
Apr 7, 2009. 5:20 AMlilykoart says:
Great Idea! i was looking into rainbarrels, but saving waste water especially from my washer is also a good way to get "free" water. i use a biodegradable detergent, plus borax powder, and a bit of vinegar in the bleach dispenser. wonder if borax would be ok for the plants? btw, borax is an ingredient used in the most effective ant killer...
Jun 24, 2009. 1:02 AMausisit says:
Both borax and vinegar are good to help keep the ph adjusted. The Boron in the borax will help with the roots and any fruit growing on the plants
Oct 4, 2007. 4:10 PMausisit says:
This is a great idea as the politicians restrict the water be used the water going up to form rain reduces so there fore less rain. I am going to use this idea it rocks.
Now if you put some sponge rox in your filter as directed at ausis sponge rox page you would be helping the environment greatly.
Reducing heavy metal bioaccumulation we understand is a big phrase to digest however it is described simply as follows: Heavy metal bioaccumulation such as in large fish they build up toxic levels of mercury which we all know is poisonous, our sponge rox help in reducing heavy metal bioaccumulation by trapping these poisons FOREVER...
Apr 7, 2009. 5:29 AMlilykoart says:
Detoxamin the heavy metals out. google Detoxamin :)
Jun 22, 2009. 7:42 PMoakironworker says:
Chelation = snake oil =stupid = detoxamin
Jan 27, 2009. 10:48 AMplzspoilme25 says:
love it but way to complicated for me to build....lol, how much for u to build me one, LOL
Sep 6, 2008. 11:46 AMmossDboss says:
why not just re-use this water for the wash? You could filter the water through sand and maybe a bed of carbon. Re-use the water a few times for the wash then for the garden?
Aug 10, 2008. 12:56 PMkurobankai says:
Good Idea 4 my FYP...hehehehehe.... will do it in Malaysian mechtronic style
Jul 26, 2008. 7:47 PMBardouv says:
Great work with the instructable. I did something like this a couple of weeks ago. I have my washing machine and both showers hooked up to a system similar to yours. We never had to add a timer, we just ran it whenever and if the soil got too wet in one spot we moved it to another.
Jul 19, 2008. 7:13 AMservant74 says:
Great project. ... From what I remember in the US, they stopped selling phosphorus based detergents many years ago (1970's?). I have thought of using air conditioner water that comes from de-humidification. But I think (but don't know) if it has to many dissolved metals to be safe. Yea, the Ausies, NZ, and middle east folks all have a different perspective on water. The western (non-CA) US used to (think pre-1950's). Also recycling in OZ is taken to a level I have NEVER seen in the US. ... For some things like this, I would like to see the US should follow the OZ and NZ folks. In OZ (Australia) there seems to be a push to build nuke power plants, but they have the resource of land that would make huge solar farms (and possibly wind farms) pretty near possible. I am sure they are looking into it. From what I have read it seems like the nuke plants are being politically pushed... such is life in our world today.
Jun 7, 2008. 6:14 PMthermoelectric says:
What program did you use for the schematic
Jan 24, 2008. 4:40 PMScottSEA says:
Excellent Idea, great instructable. Well done. Have you considered solar to drive the pump?
Jan 20, 2008. 8:43 PMKatanaman says:
Is it possible that instead of a pump to drain the water that you could just make use of gravity by driling a hole at the lowest point possible and just attaching a rain water style lever faucet? Also water won't stagnate as long as it has movement, so once again with use of gravity, it might be possible to just run a narrow tube from the bottom to the top so it might keep a constant flow, thus creating a perpetual movement from the weight of the water. Just a thought.... (another Aussie idea).
Sep 28, 2007. 12:45 PMRadBear says:
I have three questiions. 1) Can you give us more info on your filter? 2) Does the detergent harm the plants or degrade the quality of the soil? 3) for electronically challenged folks such as myself is there a off the shelf pump controller available? Excellent idea, great executuion and a very good instructable!!!
Oct 1, 2007. 1:48 AMDrew-Oz says:
I've only just found this instructable and am reading the responses first, so this might be covered in the text, but...
Easy solutions..?
Laundry detergents generally contain things that gardens don't like in big quantities, such as salt and phosphorous, so best just to buy detergents that are formulated specifically for grey water systems. Here in Aus, there are an increasing number of brands that produce such a product, and it would appear the market is growing. If your supermarket doesn't stock these, maybe you could buy online. So detergent worries could be easily sorted when you buy. Hand soap or shower products (shampoos etc) are a little more tricky, so be cautious about using your shower/hand basin water too.
Pumps are used in the boating industry a lot, especially water-level-triggered bilge pumps. They're almost always 12V so should be easy to hook up to a common, or garden variety, mains transformer. Now unfortunately, as soon as you attach the word "boat" to any product, you can almost double the price, so you'll have to shop around, but there are loads of different models and capacities available. Why not Google it?
Web references:
There is a gardening programme that has been airing in Aus for years. They publish "fact sheets" about all sorts of things:
http://www.abc.net.au/gardening/stories/s1366316.htm
Check out these guys too:
http://www.sgaonline.org.au/info_greywater.html
Heck! Why not just Google "grey water"...?
Oct 29, 2007. 5:22 PMHawaii00000 says:
Yep, the drought has really changed peoples lives in Australia (and i guess its for the better). When I went back a few months ago I was amazed at how water-conscious everyone has become. I think you Yankees could learn a lesson from us Aussies.lol
Oct 29, 2007. 5:23 PMHawaii00000 says:
Aussies RULE
Jan 15, 2008. 4:55 AMNoodle93 says:
Yeah but we're so freaking far away from anything except Asia and New Zealand.
Oct 25, 2007. 3:59 PMsmokehill says:
Boat bilge pumps are one of those tools that you keep find more uses for. I've used Rule (brand) pumps from online suppliers (cheap) for everything from basement sump pumps to watering saplings in remote locations, spraying, etc. My first $15 pump (no auto shutoff) served as a garden sprayer, running off my 12v tractor btry, for almost 10 yrs -- until I drove over it. I think the auto shutoff for their 350 model (350 gpm with no lift) is another 12 bucks. I use another for the homemade rock waterfall in my front yard. They have a built-in filter that's easy to clean, but if there's a lot of crud in yr gray water it might be best to rig up some pre-filter to save constant fiddling with it. Usually you can find better prices for their hosing if you buy sump pump hose instead of from the boat yard; adding "boat" in front of something really does multiply the price, usually. One of my neighbors whose well went dry for six months used one of these (bigger model, 1000gpm) to fill water barrels from the river every evening, to water his livestock (and himself). I'd do an instructable on the big rock waterfall (total price $45), but am too lazy to take it all apart. Basically two 7-dollar mortar tubs, the pump & a 12v supply, and a scrap of old garden hose. Plus the rocks to hide it all. Anyone could figure it out, tho. The advantage of the boat pump in this application is that you can easily change the water level it kicks on at by just hanging the pump at different levels in the container, since it operates electronically by sensing when it's sitting in water -- thereby not having to muck about with moving floats that hang up, etc. -- and cheap toggle switches can be easily rigged up for different uses. I also feel better with only 12v going into wet environments, rather than 110v. Call me chicken .... Bilge pumps should be listed right along with duct tape & baling wire -- essential for the survival of mankind.
Apr 23, 2009. 6:26 PMCulturedropout says:
These guys have a pretty good selection of various kinds of AC and DC pumps at decent prices. I shop there a lot because they're local, but they mainly do business via web and mail orders.
https://www.surpluscenter.com/water.asp?UID=2009042320224437&catname=water
Apr 17, 2009. 8:38 PM2 stroke says:
I also feel better with 12 volt going in wet environments
Jun 29, 2008. 1:13 PMDerin says:
chicken(you asked for me to call you chicken)
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:slemke
