Step 4The mechanicals of the project.
The solution was to put the pump on its side to prevent air pockets from being created. A year later I think this mounting method was not in the best interest of the pump. The pump seems to have lost its punch, it still delivers water but not like it use to. I suspect the pump being on it side has let water seep into the motor bearings (only a theory).
The pump is mounted on a aluminum frame. The frame is secured to the bin at the top of the frame. This was done so that the bin is watertight. Any mounting holes in the bin are above the high water line. Also mounted on the aluminum frame is the 2 water level switches. These are sealed magnet & reed switch units and can be purchased at spa shops or here in Australia at Jaycar http://jaycar.com.au or Altronics http://www.altronics.com.au.
To stop the pump from sliding around at the bottom of the bin it is cable tied to the aluminum frame.
Add Comment
