Step 5Wiring it all up.
For the power cord I used a power extension lead and chopped it in half. This method left me with a molded power socket for the lead that goes to the pump. That way I didn't need to butcher the existing power cord on the pump. Alternatively you could mount a power socket on the case of the controller.
Please ensure that the earth wire (green/yellow stripe) is connected from the power cord through to the lead going to the pump. To join the earth wires together I used a crimp lug that was then bolted to the transformer chassis (using star washer to ensure a good connection to the metal).
The transformer I used had flexible leads so I crimped the 3 neutral wires (blue) together using an insulated joiner (then heatshrink was placed over it).
To connect the 3 LED's on the remote indicator panel you need 4 wires. You can use Cat5 or phone cable. I also had a power LED that is mounted in the controller box itself (not remotely).
The remote indicator panel is made from a hobby box that you can purchase from electronic stores like Jaycar, Altronics, Dick Smith, Radio Shack etc. The lettering I used was Letraset rub on lettering. The weatherproof polycarbonate box was purchased from an electronic supply store. Ensure that it can be sealed to prevent rain from getting in.
Since you will be having a pump that is submerged in water you must power the controller / pump from a safety switch protected power outlet. You can find cheap extension cords that have a safety switch built into the plug.
Add Comment
