Background
An abort valve is a very important safety feature of a launcher. On occasions you will encounter a situation where an already pressurised rocket needs to be prevented from leaving the pad and pressure in the rocket needs to be released. Some reasons for aborting a launch include:
- The recovery system malfunctions or accidentally deploys while the rocket is still on the pad.
- The range may become unsafe such as when people, vehicles or animals enter the range.
- A slow leak may develop that might lead to a catastrophic failure if pressure is not released quickly.
You may want to prevent water from going back down the air line for two main reasons:
- Keep as much of the water in the rocket as possible.
- The water may damage your pump if it is designed only for air.
It should be possible to attach this mechanism to the air line of most existing launchers if they're not already fitted with non-return valves. In the procedure below we integrate a simple non-return valve into the pressure release valve.
For more water rocket construction tutorials please visit:
http://www.AirCommandRockets.com
Remove these ads by
Signing UpStep 1Materials Needed
- 2 x Gardena quick connectors
- Gardena extension adaptor
- Hose clamp
- Epoxy glue
- Sewing pin with a round head
- Nylon String
I would have to say, an abort valve is almost as important as the actual rockets structual integrity.
I build abort valves on every launcher setup, especially ones which do not have an active pressure gauge built into the launcher.
Many times I have had a loaded rocket, which would not launch. Generally when it tips slightly and the quick connect gets jammed. Without an active gauge, you can not tell whether the air has leaked and it is not loaded, or whether it is jammed...
I would throw rocks at it before moving in to touch the rocket laucher....
Abort valves are our given grace, in a very dangerous past time...
They are a necessity and so is this I'ble.
You should post that u-tube vid of the teacher gettin' smacked in the face, or was it a near miss? I think it was a near miss...
Anyway you don't want to cop a rocket in the face, not nice.
