Water Table, for the Kids by theerikjohnson
Contest WinnerFeatured
I decided to make a fun water table for my son’s first birthday. He loves water in the sink and the bathtub so instead of getting a boring old tiny pool, I went this route. I wanted fountains and sprayers and a self contained reservoir and pump so it wouldn’t need to be attached to the hose. I got all the goods at a local home-improvement store and got it together in about 2 hours.
Step 1: Materials and Tools
Materials needed:
a plastic storage bin with a cool lid (I got a couple of these in a two-pack)
a 330 gph statuary pump (in the garden pond section)
3/4” x 5’ polyethylene plastic water pipe (the price tag said “3/4” x5’ NSF PE 160PSI STICK (PEP)”)
3/4” insert plug (in the same section as the pipe above)
3/4” 90D elbow insert
3/4” tee insert
3/4” ID vinyl tube (I got a 10’ piece)
and a few simple tools:
a hand saw
a power drill
various drill bits, one a bit bigger than the outer diameter of the pipe and a few smaller ones
a utility knife (or something else to cut the vinyl tubing)
Step 2: Drill some drainage holes
Start by drilling drainage holes on the lid of the bin so that any water squirted out of the fountains will not pool on top but drain back into the reservoir. On this cool lid, I put about a 3/8” hole at every intersection of the molded texture, which happens to be the lowest point on the lid.
Step 3: Plumbing Structure
Next cut some 2” lengths of black pipe with your hand saw (or a power miter box saw) and assemble the three tee inserts and four 90D elbow inserts into the main plumbing structure.
I found that it took a bit of force to get the pipe onto the inserts. What helped was soaking the black pipe pieces in really hot water for 30 seconds right before putting them on the inserts. It helps to have a plan of action and a big bowl of hot water.
Step 4: Drill holes for fountain parts
Lay the main plumbing structure on the lid to find the best location for the holes that will allow the vertical fountain pipes to come above the lid. Mark the spots with marker and drill them out with bit a little larger than the diameter of the black pipe.
Step 5: Fountain parts
Take the remaining black pipe and cut it into six pieces, varying the length a bit. Four of those pieces get an insert plug and the remaining two get a 90D elbow insert, followed by two of the ones that got plugs. You should end up with the four vertical fountain pieces.
Step 6: Drill a hole for the power cord
Drill a hole in the side of the bin, below the rim, for the pump’s power cord to pass through. Then make a vertical cut through the rim to that hole with your hand saw.
Step 7: Get the pump in the bin
Pass the power cord through the hole in the bin by cramming it down the cut you made. Place the pump at the bottom of the bin. Attach the plumbing assembly to the top of the pump with a small piece of vinyl tubing.
Step 8: Assembly
This is the tricky part: pass each of the vertical fountain pieces through the holes in the lid and attach them to the plumbing assembly while holding the lid on partially. Close the bin and adjust the positioning of everything so that the fountain parts are roughly vertical.
Step 9: Make some holes for the water to come out
Drill small holes in the plug inserts that point up. Small is key here. If you make the holes too big before you test the water pressure, you could end up with not enough water pressure. You can’t re-drill a smaller hole, only a bigger one. So start small.
Drill some holes along the underside of the horizontal fountain pipes. Take it easy with the size and number of them; you can always add more later.
Step 10: Fill it up and test it.
Fill the reservoir with enough water to cover the pump by a couple of inches. You can pour or hose water right onto the lid. Plug the pump in to test the water pressure coming out of the fountains. If it’s too much, unplug the pump and increase the size of a hole or two and test it again. Keep this up until you get the perfect pressure for fun.
phinch says: Jul 8, 2012. 11:20 PM
Thanks for the inspiration. I built a similar table for my almost two year old using yours as a guide.
I added a shallower tub to the top with a standpipe so that the she could splash in a few inches of water. The fountain pump feeds a slip fit pvc pipe fitting, so she (or I) can reconfigure the fountain.
today we added dish soap, that was fun.
theerikjohnson (author) says: Jul 9, 2012. 5:19 AM
Great. I like your modifications. Did the soap affect the pump's performance at all?
phinch says: Jul 21, 2012. 1:53 PM
i didn't notice any difference. It's a good idea to fill the reservoir with as much water as it will hold, because the foam will eat up a lot of the water. my pump almost ran dry. I wasn't too worried, because I've accidentally ran my pump for days at a time dry when it used to be a garden pump.
Today, I added an umbrella for shade.
Broom says: Jun 1, 2012. 11:18 PM
Needs a video!
theerikjohnson (author) says: Jun 23, 2011. 2:21 PM
Thank you all for your kind words. Stand by for Water Table 2.0.
malejko says: Mar 14, 2012. 12:00 PM
It's getting warm out again.. before I go and attempt version 1.0, what's in store for version 2.0? Worth waiting, or just make both!?
oworks says: Sep 3, 2011. 5:46 AM
I made it for my 1 year old son. He loves it. Thanks for the instructable.
I use bath water pump (KP-103) in japan. http://www.koshin-ltd.jp/products/domestic/bus/std.html
canida says: Aug 22, 2011. 2:15 PM
This is awesome!
creativecherry says: Aug 20, 2011. 9:11 AM
Very COOL! Me-ma will be the greatest grandma ever when I get this made for my crumbsnatchers! Along with a water balloon fight what could be more fun! Another simple water toy we enjoy in the backyard is dishsoap bottles...even the littlest ones can squeeze softer bottles and soak Me-ma and sibs!
jameskoontz says: Aug 10, 2011. 11:59 PM
Made it and love it. No extension cords in use, and bought a portable gfci outlet adapter for extra safety.
ATTILAtheHUNgry says: Jul 13, 2011. 5:42 PM
Excellent idea, and good work winning the contest!
bajablue says: Jul 13, 2011. 4:42 PM
BIG CONGRATS on a fantastic winning project!!!
ehudwill says: Jun 28, 2011. 5:16 AM
My youngest daughter would love this. I had an idea to make something like this but I never conceived of it in a bin. Great job.
bonnie13 says: Jun 24, 2011. 8:35 AM
Dangerous
theerikjohnson (author) says: Jun 24, 2011. 11:25 AM
My son has not been harmed using this toy. It probably has something to do with the fact that I supervise him while he is using this.
This toy is dangerous if you expect it to babysit while you watch TV. But if you will be diligent in your supervision and use common sense, then it's perfectly safe.
Neuronscream makes some great suggestions if you're nervous about this.
mountainmandan says: Jun 23, 2011. 1:06 PM
This is really cool! My 1 year old nephew would love this! :-)
zyonchaos says: Jun 23, 2011. 5:52 AM
Love this, now to scam money for parts the nipper will love this
Great work
laughoutloud says: Jun 22, 2011. 5:21 PM
I'm gonna give it a go...my ruggy will love this...
Neuronscream says: Jun 22, 2011. 3:33 PM
This is a wonderful idea for a hot summer!
I would caution though that AC power and wet children are a bad combination. I would suggest adding an extension cord to the project which is positively locked so it can not be undone either by tripping over it or a curious kinder. The best protection would be to place the pump plug end and the extension cord end into a small IP65 box. And then make sure the whole thing is plugged into a GFCI power outlet that you have tested. Never assume the GFCI outlet is working especially if it is outdoors, rain and cold take their toll pretty quickly on them. But if you test and it trips and resets correctly, you will be okay.
Mrballeng says: Jun 21, 2011. 12:14 AM
Send me a postcard from Florda. Good Work.
l8nite says: Jun 20, 2011. 6:03 PM
I think my Gbrats are going to go nuts over this ! Great idea and well laid out "ible"
DanteDante says: Jun 20, 2011. 1:23 PM
This IS brilliant, and soon it will adorn my patio as well.
Great work!
somewhiteguy says: Jun 20, 2011. 6:45 AM
This is freaking brilliant. My daughter loves playing in water, but we don't have any real toys she can play with. Definitely turning this into a weekend project. Thank you for posting. Awesome ible.
skiedra says: Jun 19, 2011. 10:48 PM
Great idea! :) Thanks for the instructable
jessyratfink says: Jun 19, 2011. 4:12 PM
Seriously a great idea - and your son is too cute!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
