Water Can Fix
820
12
Posted in HomeGardening
Introduction: Water Can Fix
About: I have many hobbies that I like to do, so many that I dont always have time for them, and sometimes I may leave a project unfinished for a while as I start a new one. I have a website where I sell leather wa...
Just a cheap but effective fix for a broken water can. Enjoy!!
Step 1: Pcs Needed
The shower tip on my water can broke, so I took some PVC parts I had and made a new one. These cans are very expensive, so this was better. And it even worked better than expected. I used the can I already had, a small length of 3/4" PVC pipe (24" or so) and a 3/4" PVC cap.
Step 2:
I drilled several holes in the cap to act as a shower head, and then put it on the end of the pipe with no glue.
Step 3:
I tried the pipe on the water can and it fit very well and tight, but I wrapped a little electrical tape on it really tight just for extra support.
Step 4:
As you can see, it works really well, and now I can water at the base of my plants without bending over and I dont waste any extra water this way. Most plants benefit from the water in the dirt and not on the leaves. I have seen water cans with the extended shower head go for $80-$120 (which is ridiculous) in some stores. This one cost nothing, because I had all of the parts just taking up space in the garage. Hope you enjoy!!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    2 Comments
    I'd suggest using an expansion fitting to get a bigger diameter and then drill more but smaller holes in the larger end cap. Will give you more of a shower effect.
    If you don't permanently attach the endcap, you can pop it off when a leaf gets in the can and blocks the water flow.
    Great Idea. I hate my watering can cause it has a flat face and it always dribbles instead of showers. I'm gonna try your fix.
